by tntv [OP] » June 15th 2012, 7:54pm
by MuRKRoW » June 15th 2012, 8:16pm
by redfury » June 16th 2012, 2:47am
by Leeann_93 » June 16th 2012, 4:01am
by bdar34 » August 1st 2012, 8:41pm
by sfeaver » August 3rd 2012, 3:23am
by chevymaher » August 3rd 2012, 11:13am
bdar34 wrote:Hi Everyone,
Hope all are doing well! I am new to the Forum but certainly not new to many of the issues that come up with the Chevy Astro. My Astro is a 97' and I wanted to post to get everyone's take on an issue that I am having with the AC Compressor. I am on my 4th compressor in a short length of time, and I am not sure what the issue is.
Last July 2011, I took the van into my mechanic's shop to have the AC Compressor changed out because there were a few leaks in the system and the AC stop leak treatments were not working anymore. This was the original factory compressor. He changed out the compressor along with the Evaporator/Dryer and other parts in the system.
So then, fast forward to this May 2012, the replacement compressor starts making noise where the clutch was squeeking/slipping and there was a burning smell coming from the AC and the AC was blowing hot. I brought it in to the mechanic, and he changed out the compressor along with all the other parts originally changed under warranty. So I get the car back and then 2 days later that compressor does the same thing. I take it back, and he changes out everything else along with the air hose this time, and then within a matter of days the same thing happens again.
Bring it in once more, and the manufacturer/supplier of the compressor he was using tells the mechanic that it may be an electrical issue. However, the battery and alternator tested fine, and the voltage going to the compressor tested fine according to the mechanic. So I asked him to get me a standard new compressor from Auto Zone instead of from his supplier, and he put that in and everything was working fine for about 2 weeks.
Was drving the Astro yesterday with the Auto Zone compressor and it started blowing hot air for 2 or 3 minutes and then it turned cold again and stayed cold. I don't want this new compressor to burn out again, and so I am trying to think of what else could be the problem. I did some reading on the forum, and the only things I can think of are the High and Low Pressure Cycling Switches. I spoke to the mechanic and he did not change those out. Can bad cycling switches damage the AC Clutch that quickly? What does everyone think? I really do appreciate the info. Thanks!
BDar
It is currently February 28th 2021, 4:17pm
Climate Control Forum |
Previous topic Next topic |
Sponsors |
