1993 safari ac/compressor quit working
Postby rmtech02 [OP] » July 4th 2012, 6:03pm
Hello,
I have looked over the posts but dont find what pertains to me anywhere, here's the problem and what i have done, any help would be appreciated :)
I have had the van for 2 years now, and the compressor has kicked on and off every 10 seconds the entire time it is on....it was relatively cool so it wasnt an issue until Saturday when the compressor quit kicking on....
1. I checked the fuse...i checked all the fuses in the fuse block, and they are all fine.
2. I had the system evacuated of the old freon and put the new type in there to the correct amount.
3. I checked the pressure switch it has continuity, and i jumped it to check and see if the compressor kicked on...nothing.
Question 1: When i check the connection at the compressor(two wires), and have the AC on and blowing, i dont get any voltage there, or continuity.....should i be getting 12 volts there or something??
Question 2: The repair manual shows there is an under hood fuse box...i don't see one anywhere.
Is there anyway to "cheat" the compressor clutch to see if thats what the problem is?
Thanks, and have a safe 4th,
Randy
rmtech02
Years of Membership: rmtech02 has been a member for 11 full yearsrmtech02 has been a member for 11 full yearsrmtech02 has been a member for 11 full yearsrmtech02 has been a member for 11 full yearsrmtech02 has been a member for 11 full yearsrmtech02 has been a member for 11 full yearsrmtech02 has been a member for 11 full yearsrmtech02 has been a member for 11 full yearsrmtech02 has been a member for 11 full yearsrmtech02 has been a member for 11 full yearsrmtech02 has been a member for 11 full years
Topics: 9
Alias (AKA): Randy
Re: 1993 safari ac/compressor quit working
Postby chevymaher » July 4th 2012, 7:09pm
The plug at the clutch. One side should read ground. With the system on the way you described the other side should have 12V.
Clutch is probably fine your not getting juice to it.
Postby Speedsmile » July 4th 2012, 7:13pm
1. The compressor should get 12 V when A/C is turned on, since the 12 V activates the electromagnetic clutch.
2. Check if you get 12 V at the two wires for the low pressure sensor, from what you describe there isn't probably any. Which could point to a fuse, but it depends on the exact wiring for your year.
3. The underhood fusebox is located just left above the battery, bolted to the top section of the firewall. It has two 'click mechanisms' on each side.
Hope it helps, good luck!
Speedsmile
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Speedsmile has been a member for 9 full yearsSpeedsmile has been a member for 9 full yearsSpeedsmile has been a member for 9 full yearsSpeedsmile has been a member for 9 full yearsSpeedsmile has been a member for 9 full yearsSpeedsmile has been a member for 9 full yearsSpeedsmile has been a member for 9 full yearsSpeedsmile has been a member for 9 full yearsSpeedsmile has been a member for 9 full years
Return to Climate Control
It is currently November 27th 2020, 7:17am
Climate Control Forum
Date: Nov 19 '20
Time: 9:33pm
Date: Nov 18 '20
Time: 5:15pm
doogaloo
in Climate Control
Comments: 9
Date: Nov 09 '20
Time: 11:08pm
Date: Oct 31 '20
Time: 9:45pm
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
