A/C Switch logic
A/C Switch logic
Postby Broadbent [OP] » September 9th 2012, 6:00pm
Hello,
UK Newbie on a continuing quest to return an AWD Astro Safari to the road. All things now work except the A/C. The clutch went on the old pump and my youngest son bought a new replacement, which we swapped out. At the time he just needed his van running so off he went. As I'm now tasked with selling it, I'd like the A/C to work.
On the right of the instruments is a sliding switch that about halfway down its travel starts to make reference to A/C. Is this the main A/C ON switch, or is there some other master? Midway across the dash there is another switch which seems to control Rear A/C. What does this switch actually do? Does it just route cold air from the front into the back via some hidden fan? Can it switch the A/C on independently of the front A/C switch?
Why do none of them seem to do anything? :confused:
All advice gratefully received.
Broadbent
Years of Membership: Broadbent has been a member for 8 full yearsBroadbent has been a member for 8 full yearsBroadbent has been a member for 8 full yearsBroadbent has been a member for 8 full yearsBroadbent has been a member for 8 full yearsBroadbent has been a member for 8 full yearsBroadbent has been a member for 8 full yearsBroadbent has been a member for 8 full years
Alias (AKA): Ibex
  • REAR WIPER AND A/C SWITCH PROBLEM
    by crittermo » December 8th 2020, 10:40pm in Climate Control
    December 10th 2020, 7:49pm
    March 9th 2021, 2:22am
Re: A/C Switch logic
Postby Broadbent [OP] » September 10th 2012, 4:54pm
Too tough eh? Try this one;
My Chilton manual says that a light green wire goes from the cockpit switch to the A/C compressor via an A/C low pressure cut off switch. :? I found the wire, but I can't get any life to the compressor. Can anyone tell me where this Low pressure switch lives? There is no signal from the switch to the compressor, so I guess the low pressure cut off switch may be as far as it gets. I'd like to check this out. Having done so, all I can do then is to take it to a specialist to gas it up to see if it works? :banghead:
Dave
Broadbent
Alias (AKA): Ibex
Postby chevymaher » September 10th 2012, 7:22pm
Under the hood on the left. A silver canister. Low pressure switch is on that. 2 wire plug.
Return to Climate Control
It is currently March 9th 2021, 2:22am
Climate Control Forum
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
Toskavat
in Climate Control
Comments: 14
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
in Climate Control
Comments: 14
Date: Feb 17 '21
Time: 2:47pm
