Why doesnt my A/C work?
Postby Rolling_Rock [OP] » September 23rd 2012, 5:01am
its a 2002 astro..
I KNOW its broken - what I'm wondering is what is the most COMMON reason for failure - I know these are all mass produced - so someone else with a 2002ish astro with a failed AC probably failed for the same reason as mine did.
So my question is, what is the common failure point on this era of astro?
Ac compressor broken?
Leak in system?
Low/no refrigerant in system?
All of the above?
Other?
What the most COMMON reason for faiure?
Thanxxxx :wave:
--rox
Rolling_Rock
Years of Membership: Rolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full years
Topics: 26
Van Model Year: 2002
Extra Info: cargo version
  • Blower motor doesn’t work when accelerating neither heat or
    by Mpoynter » November 5th 2020, 7:24pm in Climate Control
    November 6th 2020, 4:12pm
    April 13th 2021, 10:43am
Re: Why doesnt my A/C work?
Postby Jasen » September 23rd 2012, 5:57am
Low refer juice would be the first place to look. Get a big can and fill it up and see if the clutch engages.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Rolling_Rock [OP] » September 23rd 2012, 6:06pm
Jasen wrote:Low refer juice would be the first place to look. Get a big can and fill it up and see if the clutch engages.
Cool thanks -- its been about a million years since ive filled an AC -- what kind of can do you reccomend I get to do the inital fill - and is it intuitive to do?
thanxxx
-roxxx
Rolling_Rock
Topics: 26
Postby Corsemoto » September 23rd 2012, 7:04pm
I usually like to start with the larger 18oz can of refrigerant with gauge if you don't have separate gauge kit. Pretty straight forward hooking up to low pressure port. If it's really low it might take an additional can before it has enough refrigerant for compressor to kick on. If you think you have a leak, worth getting a can that has dye in it to trace.
Front A/C is 3lbs total I think.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby Rolling_Rock [OP] » September 23rd 2012, 10:57pm
^ Like a boss! Thanks alot! Ill try this!
Rolling_Rock
Topics: 26
Return to Climate Control
It is currently April 13th 2021, 10:43am
Climate Control Forum
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
Toskavat
in Climate Control
Comments: 17
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
in Climate Control
Date: Feb 17 '21
Time: 2:47pm
