AC compressor will not shut off
Postby Knrichter [OP] » March 20th 2013, 1:29am
I just got my van back from the shop-
I happened to pop the hood to check the oil and noticed my ac compresor lines and canister to the firewall were completely iced up-
I started it up, turned off the heat/ac and blower. As I looked around the engine compartment, noticed the compressor was running (obviously from all the ice on the lines), the clutch was spinning as if the ac was on.
Any suggestions?? Bad relay maybe, but why would it keep running?
I ended up unplugging the plug on top of the compressor just to stop it. Another thing that puzzeled me was when the blower was running, sometimes it would come out of the vents, and sometimes not. This at an idle.
Any help would be appreciated-
Oh did I forget to mention I've had this since '03 and have racked up approx. 200K miles- Maybe time to retire it.
Thanks,
Ken
Knrichter
Years of Membership: Knrichter has been a member for 7 full yearsKnrichter has been a member for 7 full yearsKnrichter has been a member for 7 full yearsKnrichter has been a member for 7 full yearsKnrichter has been a member for 7 full yearsKnrichter has been a member for 7 full yearsKnrichter has been a member for 7 full years
Alias (AKA): Ken
Extra Info: Gladiator Conversion
Re: AC compressor will not shut off
Postby chevymaher » March 20th 2013, 1:57am
Switch panel that controls the blower motor, hot/cold function and vents.
It is probably shot. And it is time for a trip to the junkyard.
Postby sfeaver » March 20th 2013, 3:45am
Try unplugging the plug from the sensor on the accumulator (silver can near evaporator core). This is the low pressure switch. When low side drops to around 19 psi it should open and tell PCm to turn off the compressor. When it rises to around 40psi it tells the PCM the compressor is needed. Then the PCM increases idle and adjusts timing, and energizes the A/C compressor relay. This is so the motor is ready for the load of the compressor and you dont feel it.
But, by unplugging it and it turns off will tell you that switch is bad. That can be changed without draining A/C system. If not, check the A/C relay and wiring.
Scott
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 21
Van Model Year: 2001
Extra Info: LT RWD 350ci V8
Postby Knrichter [OP] » March 20th 2013, 12:01pm
Ah - thank you. I will try that. I'm not ready for the junkyard as of yet. This van has been great to me and my family. We've driven it all over the country. No motor issues- it's still pretty strong for 245K. The body has no rust and the interior is in good shape, nice wood grain,lighting,captain chairs and fold down bench. My kids call it the time machine due to the original VCR and old school TV installed with the conversion pkg. I would love an upgrade though. Maybe a full size 08-09.
Thanks again
Knrichter
Alias (AKA): Ken
Postby chevymaher » March 20th 2013, 12:16pm
I meant trip to the junkyard as go get new switch panel for your van. OMG look at mine I never say die and just keep fixing her.
Postby Knrichter [OP] » March 20th 2013, 12:52pm
I was about to get offended with that junkyard comment :)
Everybody always asks "when are gonna retire that van"-
I think they're a little envious in some weird way...
Knrichter
Alias (AKA): Ken
Postby chevymaher » March 20th 2013, 12:58pm
Knrichter wrote:I was about to get offended with that junkyard comment :)
For me to say it is ready for the junk yard it would have to be hit by a train several times.
I saw that you thought I meant junk it. I am the last to ever say that. I just meant go get the switch panel and put it in I think that is where the compressor staying on gremlin is hiding.
Postby Big_kid » March 20th 2013, 1:14pm
The pressure switch on the accumulator wouldn't cause the compressor to run with the controls in the off position. That switch will turn the compressor on & off while the control is in the on position, but it has no power source of it's own to cause the compressor to come on. I'm with Chevymaher on this one, time to look at the AC control panel in the dash.
Firing on 6 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby thegreenmachine » March 20th 2013, 7:24pm
the ac also turns on if your selector switch is on defrost, even if you have the heat cranked.
when I was a kid, I told my mom that the defrost in the crown vic sucked, when it was rainy. She told me to run the ac on defrost as it dries the air, and will defrost much faster. newer cars do it by themselves, the only position In my '03 that doesn't turn the ac by default is the floor location.
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full years
Topics: 62
Alias (AKA): Shane a lane
Postby sfeaver » March 22nd 2013, 3:02am
I missed that part where it was said knob was in off position.. Maybe not electrical at all.. Clutch not releasing? Still could be A/C relay welded in on position.
sfeaver
Topics: 29
Images: 21
Return to Climate Control
It is currently October 28th 2020, 11:53pm
Climate Control Forum
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
Date: Oct 17 '20
Time: 7:13pm
Date: Oct 03 '20
Time: 8:08pm
charlesives95
in Climate Control
Comments: 13
Date: Sep 25 '20
Time: 3:38am
charlesives95
in Climate Control
Comments: 13
Date: Sep 24 '20
Time: 9:00pm
