Disconnect lines to rear a/c...
Postby friendlyphotog [OP] » March 27th 2009, 4:56pm
I don't use the rear a/c and would like to disconnect the freon lines that go to it or cap them off somehow. Anybody know if this can be done and where to get the parts? Thanks...
friendlyphotog
Years of Membership: friendlyphotog has been a member for 11 full yearsfriendlyphotog has been a member for 11 full yearsfriendlyphotog has been a member for 11 full yearsfriendlyphotog has been a member for 11 full yearsfriendlyphotog has been a member for 11 full yearsfriendlyphotog has been a member for 11 full yearsfriendlyphotog has been a member for 11 full yearsfriendlyphotog has been a member for 11 full yearsfriendlyphotog has been a member for 11 full yearsfriendlyphotog has been a member for 11 full yearsfriendlyphotog has been a member for 11 full years
  • Rear AC removal Block lines
    by gmcjunk » February 5th 2021, 5:41pm in Climate Control
    Last post by gmcjunk View the latest post
  • Rear heat not working
    by K-TRON » September 18th 2020, 3:51am in Climate Control
    September 19th 2020, 5:25am
    92
    March 9th 2021, 2:23am
Re: Disconnect lines to rear a/c...
Postby tnhillbilly » March 29th 2009, 11:47am
Hi friendlyphotog, I know you said you don't use the rear air but is there any other reason for wanting to unhook it? If the a/c lines are taken loose you will loose your refrigerant or freon charge and get air in the system. It would have to have a vacuum pulled and be re-charged. I wouldn't recommend doing it but that is just my :2: .
1996 Safari high top conversion rwd 175,000 miles original engine, tranny, and rear end.
tnhillbilly
Years of Membership: tnhillbilly has been a member for 12 full yearstnhillbilly has been a member for 12 full yearstnhillbilly has been a member for 12 full yearstnhillbilly has been a member for 12 full yearstnhillbilly has been a member for 12 full yearstnhillbilly has been a member for 12 full yearstnhillbilly has been a member for 12 full yearstnhillbilly has been a member for 12 full yearstnhillbilly has been a member for 12 full yearstnhillbilly has been a member for 12 full yearstnhillbilly has been a member for 12 full yearstnhillbilly has been a member for 12 full years
Topics: 22
Postby gtkane » March 29th 2009, 7:08pm
You would have to buy a set of hoses designed for "front A/C "only.
User album #4...check it out!
gtkane
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby friendlyphotog [OP] » March 29th 2009, 10:45pm
I have a leak in the system and just want to eliminate all the excess hose and connections. I drive alone in the van and don't use the rear at all... I saw some "block off caps" designed for the Suburban at at site called "rayeveritt.com" but they didn't know if the caps would work on the Astro system or not. I looked at a service manual for the Astro and it looks like it could be a pretty simple procedure if I can get the right caps or plugs...
Thanks for your input...
friendlyphotog
Postby tnhillbilly » March 30th 2009, 2:02am
You might try a home hvac dealer. I know they have caps but I don't know if they would have the right ones. If it comes to it, you can get an o-ring kit at a parts store and get hoses from the junkyard for one without rear air.
tnhillbilly
Topics: 22
Postby bkzxclusive » May 9th 2009, 9:18pm
GTkane, where can i find this set of hoses, i also want to eliminate my rear AC and use the space for secondary battery, my high pressure line going to the rear evaporator has a hole and is leaking all my freon. Plz Help, i would like front AC only.
2000 ASTRO AWD
bkzxclusive
Years of Membership: bkzxclusive has been a member for 12 full yearsbkzxclusive has been a member for 12 full yearsbkzxclusive has been a member for 12 full yearsbkzxclusive has been a member for 12 full yearsbkzxclusive has been a member for 12 full yearsbkzxclusive has been a member for 12 full yearsbkzxclusive has been a member for 12 full yearsbkzxclusive has been a member for 12 full yearsbkzxclusive has been a member for 12 full yearsbkzxclusive has been a member for 12 full yearsbkzxclusive has been a member for 12 full yearsbkzxclusive has been a member for 12 full years
Topics: 27
Return to Climate Control
It is currently March 9th 2021, 2:23am
Climate Control Forum
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
Toskavat
in Climate Control
Comments: 14
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
in Climate Control
Comments: 14
Date: Feb 17 '21
Time: 2:47pm
