04 astro rad drain plug
Postby 0fourstro [OP] » February 24th 2008, 7:30pm
I'm looking at the bottom right side of rad below lower rad hose and see a flat plug that is slightly recessed. Is this the drain for the rad and if it is how do I access it and use it to drain my rad.
0fourstro
Years of Membership: 0fourstro has been a member for 12 full years0fourstro has been a member for 12 full years0fourstro has been a member for 12 full years0fourstro has been a member for 12 full years0fourstro has been a member for 12 full years0fourstro has been a member for 12 full years0fourstro has been a member for 12 full years0fourstro has been a member for 12 full years0fourstro has been a member for 12 full years0fourstro has been a member for 12 full years0fourstro has been a member for 12 full years0fourstro has been a member for 12 full years
  • Is Rear A/C Necessary for Astro Camper?
    by rogersheldon » September 6th 2020, 3:57pm in Climate Control
    Last post by TowVan View the latest post
    September 6th 2020, 6:08pm
    96
    January 19th 2021, 12:35pm
Re: 04 astro rad drain plug
Postby gtkane » February 24th 2008, 7:43pm
Make sure the coolant is cold first.
Use small pliers to twist it counter-clockwise. The plug will not come out; just a few turns and the coolant will come out of a small tube at the bottom. Undo the rad cap for maximum flow.
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby 0fourstro [OP] » February 24th 2008, 7:50pm
Thanks I.ll give it a try, but what an unusual set up to drain the rad. I figure GM would put a winged type petcock
0fourstro
Postby 0fourstro [OP] » February 24th 2008, 8:08pm
is there any special tool for this i can purchase at napa or crappy tire to loosen this rad plug(cap)
0fourstro
Return to Climate Control
It is currently January 19th 2021, 12:35pm
Climate Control Forum
Attached by: SportsBoy
SportsBoy
in Climate Control
Date: Jan 10 '21
Time: 5:10am
SportsBoy
in Climate Control
Date: Dec 31 '20
Time: 4:43am
SportsBoy
in Climate Control
Date: Dec 29 '20
Time: 5:46am
SportsBoy
in Climate Control
Date: Dec 27 '20
Time: 5:13am
Comments: 17
Date: Nov 19 '20
Time: 9:33pm
