Little/no heat issue.
Postby Michael0413 [OP] » December 1st 2013, 2:12am
I have 2001 Astro van. I am getting little heat. Coolant is fine. I have replaced the thermostat, radiator cap, AC control modulator and the blower motor resistor (not related, fan speed issue). Heater core is 6 mos. old and I flushed the entire system clean. My next step I think is the heater control valve, no rear heat so it is the 4 port. Could also be the hot/cold actuator. Any opinions on this would be really appreciated. I am running out of things to try.
Michael0413
Years of Membership: Michael0413 has been a member for 6 full yearsMichael0413 has been a member for 6 full yearsMichael0413 has been a member for 6 full yearsMichael0413 has been a member for 6 full yearsMichael0413 has been a member for 6 full yearsMichael0413 has been a member for 6 full years
Van Model Year: 2001
Re: Little/no heat issue.
Postby RECox286 » December 1st 2013, 3:44am
Is the Heater Core getting warm at all ? It should be getting hot as the hinges if the Heater Control Valve is moving to the
open position, and the T-stat is working as advertised.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby redfury » December 1st 2013, 6:14am
possible that you hooked the heater control valve to a source of vacuum instead of a vacuum controlled source...meaning it's supposed to be connected to the lower hose coming from the firewall. The heater control valve is always open unless you apply vacuum to it, then it closes, Simply disconnecting it will ensure that the valve is open and allowing coolant to flow. That's the first thing I'd check. Beyond that, I'd say it's air in the system.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby Jasen » December 1st 2013, 6:18pm
An air bubble in the system? might need to jack up the front end and burp it.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Return to Climate Control
It is currently October 1st 2020, 5:01am
Climate Control Forum
charlesives95
in Climate Control
Comments: 13
Date: Sep 25 '20
Time: 3:38am
charlesives95
in Climate Control
Comments: 13
Date: Sep 24 '20
Time: 9:00pm
in Climate Control
Comments: 287
Date: Aug 28 '20
Time: 5:27pm
in Climate Control
Date: Aug 27 '20
Time: 12:42am
Attached by: MechBob
MechBob
in Climate Control
Date: Aug 20 '20
Time: 10:48pm
