Blower Motor/Resistor/Connector replaced - Still no air/heat
Postby jg550 [OP] » December 21st 2013, 12:41am
Hey guys, yes, this another "Crap it's cold and my heat just died" post. :)
I have a '98 LS with 128k miles on it. At the start of the summer I had some A/C issues, but nothing that wasn't fixed by replacing a couple of vacuum lines. More recently, it seemed that the heat was taking too long to warm up and that I wasn't getting as much airflow as I should. I wondered if I had a thermostat or vacuum issue. Before I got to really look into that, the blower motor died. First the low settings, and then finally the high speeds died an incredibly noisy death. Once that happened, there was no response from the system at all.
The blower had basically fallen apart, so I changed out the blower motor, hoping for the easiest fix (aside from cutting that damned cover off the old one!). However, after putting in the new one and having nothing happen, I noticed that the board on the resistor was fried, and that the lead spot on the connector had melted. Today I replaced the resistor and wired in the new connector, and as I expected, still no air through the vents. The blower is definitely not spinning. What has changed though, is that now when I mess with the dials, I can hear all the doors opening and closing (i.e. floor vents, mids, defrost) and I get that typical little "psshh" sound too.
Next steps please?? lol
P.S. The van has rear air also. Am I correct that aside from vacuum line(s) from the engine, that this system is fully independent from the front system? Because the rear seems to work just fine, aside from not blowing warm air.....
jg550
Years of Membership: jg550 has been a member for 7 full yearsjg550 has been a member for 7 full yearsjg550 has been a member for 7 full yearsjg550 has been a member for 7 full yearsjg550 has been a member for 7 full yearsjg550 has been a member for 7 full yearsjg550 has been a member for 7 full years
Extra Info: LS RWD
Re: Blower Motor/Resistor/Connector replaced - Still no air/
Postby snapper388 » December 21st 2013, 12:46am
do you have power going to the blower? if you do then you may have a bad ground on the blower motor.
snapper388
Years of Membership: snapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full years
Images: 2
Extra Info: 4.3 Mark III 2wd
Postby Herman Wiegman » December 21st 2013, 3:35am
JG
The front blower is powered by the following:
1) low blower settings powered by Fuse 12, HTR-A/C, 20A
2) high blower setting powered by Fuse M3, A/C-MAX, 35A and relay by the blower
note: there is also a ground point on the resistor/relay board which needs to go to chassis, other wise no juice will flow.
Do you have a Haynes Manual? I could send you the schematic if you want.
Herminator
Herminator, Niskayuna, NY.......1999 Safari 4.3L SLE (RWD)
Eaton Gov Lok LSD 3.23:1.........Timbren bump stops
Monster 4L60E rebuild ..............Electric fan & FelPro gaskets
10922
Herman Wiegman
Years of Membership: Herman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full years
Images: 89
Alias (AKA): Herminator
Extra Info: 4.3L RWD
Postby thegreenmachine » December 22nd 2013, 1:59am
Checked the fuse???
Sent from AutoGuide.com App
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full years
Topics: 62
Alias (AKA): Shane a lane
Postby jg550 [OP] » December 29th 2013, 6:07am
Thanks for the quick responses guys. I should have known that retail management, a couple of little kids, and Christmas would mean that I wouldn't have any time to get under the hood!!
Hooked the blower up to the battery and it worked perfectly. I had checked the 20A fuse down by my feet back when I started having issues and it was fine, but checked it again since installing the new parts and it was shot. So now it looks like I'll have some heat heading to work tomorrow! High is not working, but that is likely just the 35A fuse that Herminator was talking about?
jg550
Extra Info: LS RWD
Return to Climate Control
It is currently April 12th 2021, 7:34am
Climate Control Forum
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
Toskavat
in Climate Control
Comments: 17
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
in Climate Control
Date: Feb 17 '21
Time: 2:47pm
Users browsing this forum: ranchero7ranchero7 is online! and 22 guests
