1 3/8" thermostat housing ?
Postby webcat [OP] » September 16th 2009, 11:36pm
where do i get a 1 3/8" thermostat housing ? i looked all over online , summit , jegs etc.
The thermostat housing that was on my vortec is 1 /3/8" but the spout points off to the side , i cant have it point to the side or my radiator hose will hit my AC compressor!
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
  • AC evaporator housing
    by statesblue » January 6th 2021, 2:27pm in Climate Control
    January 6th 2021, 4:39pm
    11
    January 24th 2021, 10:52am
Re: 1 3/8" thermostat housing ?
Postby moneymaker » November 23rd 2009, 7:15pm
Did you fix it yet? I had a problem with that hose when I put the V8 in. I happened to find a hose in my shop that goes up and over to radiator, that doesnt come to the front of the ac compressor. If you need the part number to that hose, I will have to look when I get home on wednesday and send it to you.
moneymaker
Years of Membership: moneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full years
Topics: 7
Postby webcat [OP] » November 23rd 2009, 7:51pm
I got one from a older Astro at pick n pull and then tapped a hole so i could thread my temp sensor in .
But thanks!
webcat
Topics: 253
Postby $uperJoe » November 23rd 2009, 9:58pm
webcat let me see a pic of that hose and assembly. mine should plug right into the radiator with a shortening of the hose before the last bend. it will work like that and fit behind the ac comp as did on the truck but with the connection if there is a better way ill go that route
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years
Topics: 59
Postby webcat [OP] » November 24th 2009, 11:10pm
I dont have the vortec TBI intake on anymore $uperjoe , I put my multipoint FI intake back on , i was just experimenting with the TBI setup on there , i could get you a picture of the thermastat housing i used !
let me know if you could use that!
webcat
Topics: 253
Postby $uperJoe » November 24th 2009, 11:27pm
i am using the multi point as well. thats the setup i was wondering about. which setup are you talking about. i would like to see all types of pics but the tbi is not necessary for me. i am confused now.
$uperJoe
Topics: 59
Postby webcat [OP] » November 25th 2009, 12:03am
i could'nt get you multi point pics of the complete assembly just the intake but i can describe how it is !
The thermastat houseing neck points to the right and slightly to the rear about a .5" and the hose runs behind the AC compressor and then turns to go around the compressor and then goes up at a slight angle for about 6 " and then goes perfectly horizontal and straight into the radiator!
webcat
Topics: 253
Postby webcat [OP] » November 25th 2009, 12:22am
$uperJoe wrote:which setup are you talking about.
I was talking about a vortec engine and heads that i put a carb intake on and then put a adapter plate on so i could mount a throttle body from a TBI system!
webcat
Topics: 253
Return to Climate Control
It is currently January 24th 2021, 10:52am
Climate Control Forum
Attached by: SportsBoy
SportsBoy
in Climate Control
Date: Jan 10 '21
Time: 5:10am
SportsBoy
in Climate Control
Date: Dec 31 '20
Time: 4:43am
SportsBoy
in Climate Control
Date: Dec 29 '20
Time: 5:46am
SportsBoy
in Climate Control
Date: Dec 27 '20
Time: 5:13am
Comments: 17
Date: Nov 19 '20
Time: 9:33pm
