How to fix No Air from Vent / Vacuum / Intermittent AC Issue
Postby kellowatt [OP] » September 19th 2009, 12:42am
I have been having the “defrost only” or “No air flow through my vents” / “Intermittent AC” problem and have been researching all over for a solution. A lot of posts have pointed to the problem and alluded to the solution but the question which like most persons I have been asking is how do I fix it. So I just fixed the issue on my 2000 Safari and I thought I would document the solution.
Tools Needed:
- stubby (2 inch) flat head screw driver or socket/ratchet handle
- a friend with a small hand
- bright enough work light
- 2 beers if you are alone, and 2 for each friend who decides to help. (You will need these).
Parts Needed
GM Part Number - 15967970
I bought the part for CDN $10.90 in Edmonton, Alberta
Here is a picture of the part
Here is the GM Tear down for this part. The one you are interested in is #12 .
Step 1 - Identify that this is your problem part.
Find the vacuum and trace it. If its not obviously broken, trace it to the end and look for cracks on it. It runs from behind the the silver AC tank and on the right of the heater core on the passenger side under the hood. Mine looked fine at first, but as I traced my hand over, about half way down it just disintegrated. Click on any of the following thumbnails for a more detailed pic.
Image Image Image
Step 2 - Remove essential parts in the path
If you have determined that this part is bad, removed the air cleaner box and the hose going to the intake manifold. There is a metal piece to which the intake rubber hose connects, you can move it too. It will give you about 1 additional inch of work room (every inch counts! trust me). I didnt move this metal but in retrospect it prolly would have saved me 20 minutes or so.
Image Image
Step 3 - Remove the old connection from the back of the engine
This part can be tough, and if you have long skinny arms, or if you have a friend with this tenet, then you are in luck! This end is on a little valve on the back of the engine about even with the gas pedal on the driver's side. In case your existing vacuum line broke off and you are not sure where to look, just take a good look at what the end should look like as per the first pic in this post, then look at the pic below for the routing. In a dark skinny hole (hence the need for the bright worklight) on the back of the engine you will see two valves.. one points up and just above that is another which points frontwards and slightly left . The latter is the one you want. You will probably only be able use your index and middle finger. Pull hard on the connector and it will come off. When you get it off, have a beer on me!
Step 4 - Putting it back together again
Be strongly advised... Start by connecting one end of the new vacuum hose to the connector described in step 3 . You want the upper side free because if you have arms like mine, then you wont be able to see in the dungeon properly as your hand will be in the way. So place one end of the vacuum hose between your index and middle fingers on the right hand, take a good look at where the connecting valve in, then lean forward and try to reconnect it. This is the hardest part.. but dont give up. You may even be tempted to go pull the doghouse.. this will not help! When it snaps on, force it on, remove your hand and verify. If its not on completely, go ahead and force it on. When its all done, have the second beer on me. So when this end is properly connected, I suggest routing the other end above the radiator hose, and above the intake manifold, and then to the T-connector at the top. Then reassemble your intake manifold and air cleaner box.
Without taking off the doghouse cover, project should take about 30 - 45 minutes.
Now, go enjoy the whiff of air from your vents as if your truck was still new.
kellowatt
Years of Membership: kellowatt has been a member for 11 full yearskellowatt has been a member for 11 full yearskellowatt has been a member for 11 full yearskellowatt has been a member for 11 full yearskellowatt has been a member for 11 full yearskellowatt has been a member for 11 full yearskellowatt has been a member for 11 full yearskellowatt has been a member for 11 full yearskellowatt has been a member for 11 full yearskellowatt has been a member for 11 full yearskellowatt has been a member for 11 full years
Alias (AKA): kellowatt
Extra Info: SLT4.3L V6 AWD
  • No Cold Air from Front Vents / No Hot Air from Rear Heater
    by Gu3nth » July 1st 2020, 3:36am in Climate Control
    Last post by Gu3nth View the latest post
  • HVAC vacuum issue?
    by Devo » October 25th 2020, 10:54pm in Climate Control
    Yesterday, 2:03pm
    9
    41
    October 28th 2020, 6:07am
Re: How to fix No Air from Vent / Vacuum / Intermittent AC Issue
Postby lewdog » September 19th 2009, 1:28am
Great post kellowatt , I just did this one the other day myself. Mine was not the tubing to the PCV but there is a vacuum canister under the fan /heater core box. This is where mine was faulty the tubing was restricted from this point. It is a strech to reach this connection I replaced it with 1/4 poly tubing.
1998 Astro LT fe2
1996 k1500 5.0 5spd 3.43 g-80 ecsb
Reasons dont need explaining Excuses only satisfy yourself
lewdog
Years of Membership: lewdog has been a member for 12 full yearslewdog has been a member for 12 full yearslewdog has been a member for 12 full yearslewdog has been a member for 12 full yearslewdog has been a member for 12 full yearslewdog has been a member for 12 full yearslewdog has been a member for 12 full yearslewdog has been a member for 12 full yearslewdog has been a member for 12 full yearslewdog has been a member for 12 full yearslewdog has been a member for 12 full yearslewdog has been a member for 12 full years
Alias (AKA): lewdog
Extra Info: LT 4.3 RWD fe2
Postby Big_kid » September 19th 2009, 1:48am
Nice writeup! :clap: :clap: Thanks for sharing it!
:chevy:
Firing on 6 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby castle_Rock » September 19th 2009, 5:23am
very well thought out post, though by reviewing the vacuum ball at the base of the vehicle, thats where its actually confusing me, It appears to only have 1 tube going from it, where does the small black vacuum hose run to?
I posted pictures of the tubes, as I may not have it hooked up correctly. The pictures only show one splitter, I have the black splitter, but dont know where it goes, maybe now somebody can help me reconnect this, as the vacuum hoses are brand new from autozone.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Years of Membership: castle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full years
Topics: 35
Postby castle_Rock » September 20th 2009, 3:39pm
Never mind, after hard determination, i got it resolved.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby kellowatt [OP] » September 21st 2009, 5:20pm
ok castle_rock. Hope the post helped you and happy to know your issue is resolved.
kellowatt
Postby kellowatt [OP] » September 21st 2009, 5:21pm
Big_kid wrote:Nice writeup! :clap: :clap: Thanks for sharing it!
:chevy:
Thanks kid.
kellowatt
Postby olalof » September 22nd 2009, 11:03am
Thanks. Great Post.
Does this also apply to an 1994 astro ?
/Ola
olalof
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: olalof has been a member for 11 full yearsolalof has been a member for 11 full yearsolalof has been a member for 11 full yearsolalof has been a member for 11 full yearsolalof has been a member for 11 full yearsolalof has been a member for 11 full yearsolalof has been a member for 11 full yearsolalof has been a member for 11 full yearsolalof has been a member for 11 full yearsolalof has been a member for 11 full yearsolalof has been a member for 11 full years
Topics: 18
Alias (AKA): Ola Löfgren
Extra Info: LT 4.3L V6 AWD
Postby Mr_Bowtie » September 22nd 2009, 11:31am
Very nice write up! Good pictures too! :clap:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby olalof » October 1st 2009, 12:17pm
Anybody?
Does anybody know if this fix works for a 1994 Astro aswell?
/Ola
olalof
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 18
Postby Big_kid » October 2nd 2009, 2:19am
I don't know if it will work for a 94. The principles are the same, it can't hurt to try.
It's REALLY ironic- I was going to search for this thread tonight. My '06 Express van started doing the same thing this afternoon. I suppose I could tell the fleet manager I'm putting it in the shop, but I'd rather not have the down time.
Topics: 185
Images: 333
Postby flying j » October 4th 2009, 12:58am
hey olalof,
i have a 1994 and am dealing with the same issues right now also. so far I have replace all the rubber hoses in the vaccum system. I have found that there is a crack in one of the control pieces behind the heater control...i'll have to get a new heater control. You should be able to start tracing these lines from the big black ball that is located under the coolant and windshield washer resevoir. I went from there and started replacing all the lines. I did have the dog house off when I did this...it would be impossible to do without doing it. all tubing and little fitting cost me about $24 at the local napa auto parts.
I should be getting the replacement control unit this coming week and i'll let you know if it fixes the problem. Let me know if you need any other help.
jamie
flying j
Years of Membership: flying j has been a member for 12 full yearsflying j has been a member for 12 full yearsflying j has been a member for 12 full yearsflying j has been a member for 12 full yearsflying j has been a member for 12 full yearsflying j has been a member for 12 full yearsflying j has been a member for 12 full yearsflying j has been a member for 12 full yearsflying j has been a member for 12 full yearsflying j has been a member for 12 full yearsflying j has been a member for 12 full yearsflying j has been a member for 12 full years
Alias (AKA): fingalingdan
Postby dhole » October 4th 2009, 5:01am
Just did this replacement last night. The part (as you say, #12 in the diagram) was about $10 including tax from local Chevy dealer. For my 2001 Astro, I removed the doghouse and it was pretty easy to feed the hose back from the front to where it connects on the driver side mid-top engine. Also replaced the PCV since it was within a few inches of the vacuum connection. Since the hose had disintegrated within about 1 inch of the fitting in the back, I would never have been able to find where to attach the new hose by looking in from the front of the engine, (nor would two beers have allowed my fat arms to ever fit into that spot from the front) but it was easy to find and access after pulling the doghouse.
dhole
Years of Membership: dhole has been a member for 11 full yearsdhole has been a member for 11 full yearsdhole has been a member for 11 full yearsdhole has been a member for 11 full yearsdhole has been a member for 11 full yearsdhole has been a member for 11 full yearsdhole has been a member for 11 full yearsdhole has been a member for 11 full yearsdhole has been a member for 11 full yearsdhole has been a member for 11 full yearsdhole has been a member for 11 full years
Alias (AKA): Davo
Postby flying j » October 6th 2009, 4:08am
well i just got in the house after doing all the repair work to the vacuum lines in the engine compartment (last week I replaced all the lines on the driver/passenger side of the firewall).....i now have control over where the air blows out!!!
it was the vacuum lines that go through the fire wall near where the steering column comes through the firewall.
***dead images removed***
It was the two black hoses that are coming out of the firewall that were bad...not just cracked, but looked like battery acid was poured on them. So I cut them about two inches away from the firewall and replaced them about ten inches back into the wire cover goocher.
I also replaced the heater control unit in the dash of the van. The existing control unit had one of the vacuum line connectors broken off and just stuck in the vacuum line doing nothing.
I got it all put back together...a/c was working and the air could blow out and warm my feet or defrost my windshield when the following happenned.
***dead images removed***-new vs. old
***dead images removed***-view from inside
The pieces actually cut a hole in the side of the little area where the blower is spinning (not sure what it's called?). I stuck my camera phone inside it and snapped a picture.
the fan blades that attach to the heater blower motor just exploded....it was loud as hell! i wasn't sure what happenned when it came apart, but it was minutes after I had the doghouse and lines all put back together.
this is what the exploded tumbler looked like...imagine the noise that thing was making with all those parts floating around in there.
now i have the new motor/fan assembly installed and it's working great! I can't wait to start it in the morning and have hot air blow on my feet! I hope this helps you olalof, if you have questions, I would be more than happy to help any way I can!
flying j
Postby olalof » October 9th 2009, 11:11am
Thanks for the post.
I will try this as soon as possible.
olalof
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 18
Postby evil_motors » October 9th 2009, 2:17pm
olalof i love your offroad lights on the front of your van. how do you have them mounted.
1992 GMC Safari XT , Rhinolined interior, Fatmat walls and celing, Racing seats, Satin Black Dash, Taplock, Clear Corners, Check out my continuing thread with all my mods and lots of pictures.
https://www.astrosafari.com/viewtopic.php?f=9&t=3769
evil_motors
Years of Membership: evil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full years
Topics: 26
Extra Info: XT RWD
Postby olalof » October 12th 2009, 9:07am
It's a metal bar bolted to the front bumper.
Dont know if it's custom made.
Can take a picture soon.
olalof
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 18
Postby evil_motors » October 12th 2009, 11:14pm
that would be great thanks.
evil_motors
Topics: 26
Extra Info: XT RWD
Postby dentprone » October 13th 2009, 1:37am
Good deal, thanks for the writeup.
dentprone
Years of Membership: dentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full years
Postby daisykleen » October 13th 2009, 2:27am
48 bottles of bud select beer!! to start!
daisykleen
Years of Membership: daisykleen has been a member for 11 full yearsdaisykleen has been a member for 11 full yearsdaisykleen has been a member for 11 full yearsdaisykleen has been a member for 11 full yearsdaisykleen has been a member for 11 full yearsdaisykleen has been a member for 11 full yearsdaisykleen has been a member for 11 full yearsdaisykleen has been a member for 11 full yearsdaisykleen has been a member for 11 full yearsdaisykleen has been a member for 11 full yearsdaisykleen has been a member for 11 full years
Topics: 9
Return to Climate Control
It is currently October 28th 2020, 6:07am
Climate Control Forum
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
Date: Oct 17 '20
Time: 7:13pm
Date: Oct 03 '20
Time: 8:08pm
charlesives95
in Climate Control
Comments: 13
Date: Sep 25 '20
Time: 3:38am
charlesives95
in Climate Control
Comments: 13
Date: Sep 24 '20
Time: 9:00pm
