No more cold feet while driving!
Postby Hangard [OP] » November 26th 2009, 5:53pm
Seems I always have cold feet. Maybe being in Wisconsin has something to do with it, but its not even cold yet!
When the heater air is directed to the floor the passenger and the center ports work fine, but it seems GM did not want too much heat to the drivers feet. Well, its not enough of a balance as I have to turn the heat off when a passenger rides with me.
My fix? Seems to me that in a cargo van with two bucket seats that there is not much need for heat to be blowing out of the bottom center of the dog house. So on my recent cap, rotor, wires, & plugs change I did not put the duct back on after the dog house went on. Instead I did this:
What it is, is a 21" piece of flooring tube. Carpet has a cardboard tube, but this is from Flexitec - a vinyl that has no paper backing and nearly un-rip-able. Anyway, it is a 'plastic' tube ~4" diameter. I used a heat gun to soften it, kinda rolled it onto the diamond shaped port where the OEM duct fit on and now all the air blows to the driver's feet area.
I put about 600 miles on so far and it is great. I was concerned that it was not directed down, but the whole legs and feet area are nice and warm. I can now have the control on defrost/floor blend and the windows are clear and my feet are warm. Bring winter on!
1999 Astro AWD Cargo van with glass on rear doors and slider. Now with 171K. [10K in 4 months] VIN 'W' 4.3. 6000 GVWR Biggest repair: Rebuild rear differential Jan-2010
Hangard
Years of Membership: Hangard has been a member for 11 full yearsHangard has been a member for 11 full yearsHangard has been a member for 11 full yearsHangard has been a member for 11 full yearsHangard has been a member for 11 full yearsHangard has been a member for 11 full yearsHangard has been a member for 11 full yearsHangard has been a member for 11 full yearsHangard has been a member for 11 full yearsHangard has been a member for 11 full yearsHangard has been a member for 11 full years
Location: Right on the lower tip of Lake Superior - Well, almost
Extra Info: AWD Cargo 4.3
  • No heat has got me stumped
    by teafreak35 » October 24th 2020, 6:24pm in Climate Control
    October 24th 2020, 10:57pm
  • No heat, engine temp.fluctuates
    by Mberry0614 » February 10th 2021, 12:08am in Climate Control
    February 10th 2021, 12:17am
    30
    April 13th 2021, 2:00am
Re: No more cold feet while driving!
Postby webcat » November 26th 2009, 6:13pm
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby Mr_Bowtie » November 26th 2009, 6:18pm
Nice work! I have heard the I'm too hot from my wife and I have to turn the heat down...... :doh:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby Jasen » November 26th 2009, 7:47pm
I was having lunch in my van as usual at work, my boots were wet, old and wore out and my feet were damp and I was sitting sideways to get my feet infront or the heat.
So in other words, I like your solution.
Oh and sense then I got new gortex work boots. But that won't help when the temps drop into the 30's and below.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby timelessbeing » November 26th 2009, 8:29pm
I HATE the unbalanced heat. My passenger always complains about getting cooked, while my feet are cold.
Also, what's with the knee level vents that barely blow?
It's nice to see someone work on a solution, but unfortunately this one doesn't blow into the back for passenger models, down onto my toes. I tried to get into the ductwork to come up with something, but could never figure out how to remove the dash. The joints between the duct pieces also now leak because they just loosely slide into each other and the insulating foam deteriorates quickly.
2000 Astro AWD Passenger
4.3L CSFI V6 • 3.73 G80 • 4" OV lift • 30" AT tires
timelessbeing
Years of Membership: timelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full yearstimelessbeing has been a member for 13 full years
Topics: 38
Extra Info: Lifted AWD 4.3
Postby 91astroluv » November 27th 2009, 3:09am
One day, when the astro/safari lineage rises again Chevy/gm is gonna love all this free information!!!!
and......yes I believe the concepts employed in the astro/safari are well suited for green power, a real MUV Multi Use Vehicle.
Now that was great thinkin and a true testament to us owners being determined to find a harmonious balance between our astroerotica obsession and functionality!!!!
There ya go thinkin with yer HEAT stick jimmy!
Thanks a mill great solution and Happy Holidays
Trip
91astroluv
Years of Membership: 91astroluv has been a member for 11 full years91astroluv has been a member for 11 full years91astroluv has been a member for 11 full years91astroluv has been a member for 11 full years91astroluv has been a member for 11 full years91astroluv has been a member for 11 full years91astroluv has been a member for 11 full years91astroluv has been a member for 11 full years91astroluv has been a member for 11 full years91astroluv has been a member for 11 full years91astroluv has been a member for 11 full years
Topics: 7
Postby Hangard [OP] » November 27th 2009, 4:05am
webcat wrote:RE: Photo with yellow words,
I did not cut a hole in that bracket, it simply blows through and 'dumps' the air near the bottom of the steering wheel.
Hangard
Postby webcat » November 27th 2009, 12:13pm
Nice, i like to have warm feet too!
webcat
Topics: 253
Postby Jasen » November 27th 2009, 6:31pm
Was outside for a while yesterday before the hour drive north to the SIL's. Feet got a bit cold and it took for ever to warm them up on the drive. The ol' lady was doing her make up on the drive so I had some quiet time to think about this ducting thing. I had the idea of using PVC pipe, which you can heat and mold to shape, add in a Y to direct it to both foot wells and put a gate valve in the drivers side feed close to the Y so you could have even more control of the heat flow from one side or the other. Figuring the heat flow to the drivers side will be more of a direct line where as the pass side will have to turn back on itself.
200k
Ultra gauge
Topics: 260
Images: 101
Return to Climate Control
It is currently April 13th 2021, 2:00am
Climate Control Forum
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
Toskavat
in Climate Control
Comments: 17
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
in Climate Control
Date: Feb 17 '21
Time: 2:47pm
