Safari 2001 front heater fan inop
Postby gene briggs [OP] » December 26th 2009, 7:08pm
This is my first post and have been enjoying all I've read so far. Thanks to all
First, how do I get at the 'blower'? I've got heat at the coils but I'm not sure how to get to the blower itself. I've looked at the 'dash' switches. All of the wires seem fine, connections tight and no corrosion. The Blower comes and goes, at it's choice of time, but usually only for a short time. When it works all is OK but it never comes on at full power.
I've read some post's about the 'air' hose's that control the selector. Does that in any way have control of the Fan coming on and off?
I rarely have use for the heat in Key West but am in New England getting ready to head south and 'no heat' will be a bummer till I get way south. I use the Air all the time and I was having a progressive problem with it before coming North this year. Seems the fan hasn't put out full power for awhile now.
Any help is appreciated. Would have no problem replacing the fan if that's the problem but so far have been afraid to disassemble too far with out more answers. I did find one post of 'how' and 'where' blower is on a different year but it looked nothing like mine in the engine compartment. Help? Thanks
gene briggs
Years of Membership: gene briggs has been a member for 11 full yearsgene briggs has been a member for 11 full yearsgene briggs has been a member for 11 full yearsgene briggs has been a member for 11 full yearsgene briggs has been a member for 11 full yearsgene briggs has been a member for 11 full yearsgene briggs has been a member for 11 full yearsgene briggs has been a member for 11 full yearsgene briggs has been a member for 11 full yearsgene briggs has been a member for 11 full yearsgene briggs has been a member for 11 full years
Re: Safari 2001 front heater fan inop
Postby astroturf » December 26th 2009, 11:06pm
Welcome aboard. This search should get you started in the right direction. Jim
search.php?st=0&sk=t&sd=d&keywords=blower+replacement
Ps: I just looked at my 05, and its the same. You'll have to remove the radiator overflow bottle and washer bottle.
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby gene briggs [OP] » December 26th 2009, 11:28pm
astroturf wrote:Welcome aboard. This search should get you started in the right direction. Jim
My safari looks nothing like your's. When I took the overflow and the cleaner's out all I can see is the wire harness and the plug/receptacle. Do I completely take the 'box' apart to get at the blower?
gene briggs
Postby astroturf » December 26th 2009, 11:49pm
If I were in your spot I would look at this first. Jim
viewtopic.php?f=34&t=5031&p=36776&hilit=blower+replacement#p36708
astroturf
Topics: 112
Postby gene briggs [OP] » December 29th 2009, 1:16am
Wow. Help came through, thanks a bunch to one and all.
Wasn't the fan, it was the 'resistor' array. Tested the fan by applying 12volt's to it and it ran fine. The relay 'thingee' looks toasted and I'm confident it will resolve my problem when I find one. Untill than I've 'rewired' the fan 'plug' to a cigarette lighter plug and can be warm untiill the chore is completed.
If anyone is interested the 'black' on the fan plug is, of course, ground. I ran a +- wire from the battery to the fan, applied juice before removing the fan, and found it ran fine. The info about the 'relay' made me realize that 'testing' the fan before removing was a good Idea. Only wish I'd tested 'before' I removed the sound jacket/insulation!
Thanks again to all and I'll be back. gene :ty:
gene briggs
Postby astroturf » December 29th 2009, 1:37am
gene briggs wrote:Wow. Help came through, thanks a bunch to one and all.
Glad it worked out for you Gene. Jim
astroturf
Topics: 112
Return to Climate Control
It is currently February 25th 2021, 7:27pm
Climate Control Forum
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
in Climate Control
Comments: 14
Date: Feb 17 '21
Time: 2:47pm
Attached by: SportsBoy
SportsBoy
in Climate Control
Date: Jan 10 '21
Time: 5:10am
SportsBoy
in Climate Control
Date: Dec 31 '20
Time: 4:43am
SportsBoy
in Climate Control
Date: Dec 29 '20
Time: 5:46am
Users browsing this forum: Google [Bot], ptysiekptysiek is online! and 7 guests
