AC pressure low side
Postby paulbot [OP] » June 7th 2014, 1:51am
So after getting my bad spark plug finally diagnosed last week here, my 2000 Safari with 177K rewards me with AC struggling bad today. It hit 90F today with 60% humidity. Drive home is all interstate, and it didn't keep my cool.
Put the Harbor Freight gauges on it and at first, I get readings that indicate I needed freon. Something like 25 psi low, 125-150 high. Get a can of freon from the shed, hook it up to the gauges and attempt to fill er up. Then low side went way up and stayed up, and not much freon went in. I really don't have a clue how the gauges work in the block, I just know hook up the high and low lines, and open the valves.
So I have no idea where to go from here. Also, 2 years ago I rebuilt the AC with a Delphi compressor from Rock Auto, along with evaporator coil, flush, orifice tube, dryer, vacuum and recharge. Worked like a champ. I am losing some from the low pressure valve, it's always slightly oily, hence me thinking I need to add some R-134.
Any pointers?
55273 2000 Safari Cargo RWD 235K
paulbot
Years of Membership: paulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full years
Topics: 13
Images: 16
Extra Info: Cargo
Re: AC pressure low side
Postby chevymaher » June 7th 2014, 2:43am
Only use the low side. Get it up to 35 lbs when the compressor is engaged and pumping. On max A/C with the fan on high. If the compressor is cycling during the test it needs more.
Postby paulbot [OP] » June 7th 2014, 3:49am
Thanks. Compressor is cycling. I think this gauge set has seen it's last. maybe something clogged in it or some such. I have a little low side filler I'll use that if I can find it
paulbot
Topics: 13
Images: 16
Extra Info: Cargo
Postby Lumpy » June 7th 2014, 7:35pm
No gauges that I've ever used (several in the last couple months) seem to engage the fittings well on my 134a conversion. I find I have to physically PUSH the gauge hose fitting onto the low or hi pressure nipple to get gas to flow or to take a reading.
Perhaps it's something as simple as that. Hook your gauges up, keep the valves on the gauges CLOSED, and try simply pushing on the back of the connector where it meets the fittings in the van. See if that causes you to see more expectable readings.
Postby paulbot [OP] » June 8th 2014, 12:26am
I gave up on the gauge set and bought another fill hose with gauge from walmart. Can and a half of r134 and it's blowing cold again, but still only 25 psi on the gauge. When I go into town I'll get more. Had I realized it would take this much, I would have gotten another valve core for the low side fitting and fixed the leak.
paulbot
Topics: 13
Images: 16
Extra Info: Cargo
Postby Lumpy » June 8th 2014, 6:55am
PB - Is yours a conversion from R12 to 134a or is it a newer van designed for 134a?
Mine's an 89, R12 originally. I converted it to 134a.
To add freon in mine, I find it simpler to use the plastic single hose gizmo that comes with some kits. I think that's what you're describing that you used for yours. I still have to physically hold it in place. But the cheapo gauge and hose is easier to stand there and hold than the more expensive manifold type gauges.
I added some more today. Blowing really cold but still just barely above 25 on the low side.
Postby paulbot [OP] » June 13th 2014, 3:40am
Lump, it came with r-134A. got a kit similar to this- http://www.walmart.com/ip/Deluxe-R-134a ... e/16888796 Worked as it should. If I can get to Big Lots to grap another 3 cans or so, and get another valve core I'll get the leak fixed.
paulbot
Topics: 13
Images: 16
Extra Info: Cargo
Postby Lumpy » June 13th 2014, 7:04pm
That's exactly the valve/gauge thingie I use. 134a is $9 per can at my Wally's.
Postby paulbot [OP] » June 14th 2014, 2:45am
I stopped at wallyworld because it was close. $15 a can was all they had. Think it was synthetic, they have a hard time keeping regular r134 instock, they never have any. I have to go to the other side of town this weekend for Big Lots.
paulbot
Topics: 13
Images: 16
Extra Info: Cargo
Postby paulbot [OP] » July 24th 2014, 4:21am
crap. been working really well, and still is. The compressor always had a little rattle even right after I rebuilt the system, but it sat up for a week while we went to Houston for a big dog show. Today I went back to work, and it's clattering significantly louder. I had googled while on the job in the van about the clatter it was making, read a thread here that if it's clattering replace it before it locks up. Now I cant find it....
So now it's 2 years old with a Delphi compressor, looks like I need to change it again. I did go the whole 9 yards when i redid it, seals, flush orifice valve accumulator, pulled a good vaccuum etc. Here's a recording I made holding phone just a few inches away from the compressor- https://drive.google.com/file/d/0BwRrR1 ... sp=sharing
paulbot
Topics: 13
Images: 16
Extra Info: Cargo
Postby redfury » July 24th 2014, 5:38am
Sounds like the compressor is shot. I'm currently working on learning A/C repair ( on my own ) and from what I've seen, you have two different oils to use depending on the compressor, either pag49 or pag150, make sure you are getting the right stuff for the compressor you are using...that's first.
Secondly, when you replace the compressor, replace the drier and make sure you pull a good vacuum down to 29 inches for at least 20-30 minutes to boil off and remove any traces of moisture in the system.
Thirdly, if the old compressor died violently and got junk in your system, you'll want to flush out the components you can to get rid of any debris from the compressor. Never a bad idea to add an A/C filter to the system if you can manage it if you aren't sure. If you have rear A/C the rear expansion valve has a very tiny orifice that can get blocked up with debris.
The orifice tube may be blocked or partially clogged with your low side pressure issue, you'd want to replace that anyway since you'll be replacing the compressor.
http://www.aircommcorp.com/files/upload ... ooting.pdf
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby Mmusicman » July 24th 2014, 6:14am
redfury wrote:..Thirdly, if the old compressor died violently and got junk in your system, you'll want to flush out the components you can to get rid of any debris from the compressor. Never a bad idea to add an A/C filter to the system if you can manage it if you aren't sure. If you have rear A/C the rear expansion valve has a very tiny orifice that can get blocked up with debris..
EXACTLY!!! If the system is left contaminated, you will only prematurely kill the next compressor. Flush is vital... filter a good idea too. Not so much a concern if the system is still clean.
Topics: 73
Images: 49
Postby paulbot [OP] » July 24th 2014, 11:51am
Thanks for the tips. 2 years ago when I redid it, I did flush the lines new O valve seals accumulator pulled a vacuum etc. PAG oil was correct version and amount. Details on that was hazy, but I seem to remember looking it up and adding whatever it called for. Guess I'll order an AC Delco today. Thought I was getting a good one with the Delphi. I do like to go the extra lengths for a long lasting repair.
paulbot
Topics: 13
Images: 16
Extra Info: Cargo
Postby chevymaher » July 24th 2014, 2:20pm
Cleaning the system is the key. Spare no pain doing that. I know of a vehicle that had it done at a shop. It was flushed all new parts. And same thing happened in the same length of time. A filter is definitely needed in line somewhere and I don't think there is one made. Filter dryer is not a filter for solids they pass right through.
Postby paulbot [OP] » July 25th 2014, 12:08am
Yeah that's what's puzzling, I did flush the crap out of it 2 years ago. But I'll do it again, too old to be riding around in this heat with no AC. Side note, after years of buying from Rock Auto, I seem to be ordering more from Amazon since we have the Prime package. Not only were the parts cheaper than RA, I got free 2 day shipping.
paulbot
Topics: 13
Images: 16
Extra Info: Cargo
Postby CoolCat4Christ » July 25th 2014, 2:04am
chevymaher wrote:.............A filter is definitely needed in line somewhere and I don't think there is one made. Filter dryer is not a filter for solids they pass right through.
Something like this maybe???
http://www.autozone.com/autozone/parts/Santech-A-C-Inline-Filter-Kit/2000-Chevrolet-Astro-Van-2WD/_/N-je3mxZ91u1a?itemIdentifier=946933_0_0_
17553ImageImage
"If guns cause crime, all of mine are defective." -Ted Nugent
CoolCat4Christ
Years of Membership: CoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full years
Images: 7
Location: Born In East L.A. Currently residing somewhere in the San Gabriel Valley of Southern California
Van Model Year: 2002
Extra Info: LS 4.3l RWD
Postby chevymaher » July 25th 2014, 2:08am
That be the animal, nice find.
Postby CoolCat4Christ » July 25th 2014, 2:49am
Ya see.....once in a while I am good for something...besides clowning.
17553ImageImage
CoolCat4Christ
Images: 7
Postby paulbot [OP] » July 25th 2014, 4:11am
Thank you sir. The local Autozone has one in stock. Should be able to fit it in somewhere without too much trouble.
paulbot
Topics: 13
Images: 16
Extra Info: Cargo
Postby Lumpy » July 25th 2014, 5:35am
paulbot wrote:Thank you sir. The local Autozone has one in stock. Should be able to fit it in somewhere without too much trouble.
PLEASE take pics. I'm interested in where and how it installs.
Return to Climate Control
It is currently March 7th 2021, 6:45am
Climate Control Forum
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
Toskavat
in Climate Control
Comments: 14
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
in Climate Control
Comments: 14
Date: Feb 17 '21
Time: 2:47pm
