Front and rear AC switch rewired??
Postby TucsonAstro [OP] » February 12th 2010, 5:27am
Hey guys, Hi to everyone this is my first post, I just bought this a 1998 Chevy Astro LS. ITS NOT RUNNING!! but I am gonna fix it and make it my daily driver. It has rear AC. I noticed a switch on top of the rear ac control switch on the dashboard. And one on the back (SEE PICS)
I don't really know how this works but when you turn on that switch on the back, the rear blower comes on. You can"t change the speed or anything same with the front. The actual control switch (ON, OFF, SPEED) doesn't do anything, maybe just change the temperature and the defrost and all those. I don't know were those wires go to. I don't mind these rewires but I would like to make it work the way it should be.
Has anyone ever seen this or why it's done?
1997 Chevrolet Astro....4.3L V6....177000 miles......3rd owner.........All stock
TucsonAstro
Years of Membership: TucsonAstro has been a member for 10 full yearsTucsonAstro has been a member for 10 full yearsTucsonAstro has been a member for 10 full yearsTucsonAstro has been a member for 10 full yearsTucsonAstro has been a member for 10 full yearsTucsonAstro has been a member for 10 full yearsTucsonAstro has been a member for 10 full yearsTucsonAstro has been a member for 10 full yearsTucsonAstro has been a member for 10 full yearsTucsonAstro has been a member for 10 full years
Alias (AKA): Franky
Extra Info: rwd Stock
  • ???? Rear AC is cold front ac is cool ????
    by BadAsrto » August 15th 2020, 10:27pm in Climate Control
    August 16th 2020, 4:14pm
  • Ac pressure switch
    by gengomepyle » June 9th 2020, 3:32pm in Climate Control
    June 10th 2020, 10:24pm
    49
    November 29th 2020, 5:47pm
Re: Front and rear AC switch rewired??
Postby Mr_Bowtie » February 12th 2010, 5:44am
Welcome! Looks like someone went the cheap route when the switches went bad? I think your going to have to start taking the dash apart to see what they all did. I hate when I see things like that. :whack:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby Astroplane » February 12th 2010, 6:15am
One of the pattern failures is the blower motor resistor assembly located under the hood, below the blower motor. Sounds like they bypassed the switch and the resistor. Can you see the heavy gauge wires from the switch under the hood anywhere? I'm wondering if Mr.Fixit wired directly to the motor or spliced into the pigtail from the motor to the resistor pack. On the rear, there should be a conventional resistor in the blower housing. Maybe just a bad switch and lack of understanding. If you don't already have one, You need a Factory Service Manual. Best money you've ever spent for situations just like yours.
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full years
Extra Info: LT RWD
Postby Mr_Bowtie » February 12th 2010, 6:24am
If the resistor goes out doesn't the blower still work on the high setting? Why would Mr. Fixitwrong have to bypass that? :think:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby TucsonAstro [OP] » February 12th 2010, 6:47am
I will take it apart this weekend to see what's going on. I do have a parts van except it doesn't have rear ac but I'll try and make it work. I'll update this post as soon as I do it. Thanks for the replys guys.
TucsonAstro
Alias (AKA): Franky
Postby Astroplane » February 12th 2010, 7:11am
TucsonAstro wrote:You can"t change the speed or anything same with the front.
Do I understand that both front and rear A/C blowers only operate on high speed?
Mr_Bowtie wrote:If the resistor goes out doesn't the blower still work on the high setting? Why would Mr. Fixitwrong have to bypass that?
Yes, assuming the initial problem was with the lower speeds. What if the problem was with the high speed relay? It wouldn't surpise me if Fixit went from the battery or other power supply straight to the blower motor.
Does this van have rear heat? Check underneath for lines running to the drivers' side mid-van. Can you take some pics behind the coolant overflow bottle? (need to see factory wiring there) Also, look for a another factory connector inside the hole where that switch comes out.
Mr Bowtie, what do you think the chances are of the previous owner swapping heat/ A/C switches to try to get it to work and then resorting to this mess?
The red lighted switch is a nice touch.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby Astroplane » February 12th 2010, 7:15am
Also, can we have some info on the not running issue? I'd like to know as much as possible about this van now as opposed to three pages of posts later. Thanks.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby TucsonAstro [OP] » February 12th 2010, 2:26pm
The not running issue is the tranny. I have a replacement already. I just don't have a lot of time right now to do the swap.
Like I said I will take some more pics maybe today from all the places you guys told me. Thanks.
TucsonAstro
Alias (AKA): Franky
Postby astro355 » February 13th 2010, 3:16am
In this picture,
What is the discoloration on the plastic trim behind the switch?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby TucsonAstro [OP] » February 13th 2010, 9:44pm
astro355 wrote:In this picture,
[ https://www.astrosafari.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=13627 ]
That stain I just think it's some soda or something. It does have some sort of cover on there like a rubber I don't know for what.
TucsonAstro
Alias (AKA): Franky
Postby TucsonAstro [OP] » February 13th 2010, 9:51pm
Ok guys I took things apart.. That switch on the dash board is connected to the front blower fan, directly. Sorry for the crappy pics. Same with the rear. I will hook everything back the way it should be and then I'll go from there.
TucsonAstro
Alias (AKA): Franky
Postby Astroplane » February 14th 2010, 5:33am
Are you missing a switch on that front panel or was it just a cover? Rear heat in this van? For the front: Remove the coolant bottle and inspect the resistor. I'm assuming that is what started this wiring redo. If you need a new one, that will give you a new pigtail to hook to the blower motor. Maybe the factory connector for the resistor is OK. Price of a new resistor is around $45. Keep us updated. Glad to hear you are going to make it right again. No more wire nuts! :D
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Return to Climate Control
It is currently November 29th 2020, 5:47pm
Climate Control Forum
Date: Nov 19 '20
Time: 9:33pm
Date: Nov 18 '20
Time: 5:15pm
doogaloo
in Climate Control
Comments: 9
Date: Nov 09 '20
Time: 11:08pm
Date: Oct 31 '20
Time: 9:45pm
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
