AC high pressure switch
Postby bmorgoch [OP] » August 16th 2014, 12:34am
I am replacing the ac compressor in my 2004 safari (with rear ac).
I have everything undone except the high pressure switch connector. It is oriented in a way that I can't see what the "magic" trick is.
Does anyone know how to disconnect the high pressure switch connector on the back of the compressor?
I have purchased a new switch for the replacement compressor already.
bmorgoch
Years of Membership: bmorgoch has been a member for 12 full yearsbmorgoch has been a member for 12 full yearsbmorgoch has been a member for 12 full yearsbmorgoch has been a member for 12 full yearsbmorgoch has been a member for 12 full yearsbmorgoch has been a member for 12 full yearsbmorgoch has been a member for 12 full yearsbmorgoch has been a member for 12 full yearsbmorgoch has been a member for 12 full yearsbmorgoch has been a member for 12 full yearsbmorgoch has been a member for 12 full yearsbmorgoch has been a member for 12 full years
Re: AC high pressure switch
Postby chevymaher » August 16th 2014, 1:38am
Part you need to keep is the part on the wire. It has a lock on it. Find the flat part and squeeze it real good. That unlocks it.
Postby bmorgoch [OP] » August 16th 2014, 4:34pm
The connector on the end of the wire is black in colour. I found the latch that needs to be squeezed, but there is a blue locking piece between the main body of the connector and the handle that needs to be squeezed. I can't seem to get the blue lock out so that I can squeeze the handle to release the connector from the switch.
Anyone?
Bob
bmorgoch
Postby Leeann_93 » August 16th 2014, 8:07pm
I think you have to use a little screwdriver to convine the blue locking tab to get free, but keep careful hold of the tab because I'm told it has a tendency to fly away once it releases otherwise.
Return to Climate Control
It is currently January 17th 2021, 1:53am
Climate Control Forum
Attached by: SportsBoy
SportsBoy
in Climate Control
Date: Jan 10 '21
Time: 5:10am
SportsBoy
in Climate Control
Date: Dec 31 '20
Time: 4:43am
SportsBoy
in Climate Control
Date: Dec 29 '20
Time: 5:46am
SportsBoy
in Climate Control
Date: Dec 27 '20
Time: 5:13am
Comments: 17
Date: Nov 19 '20
Time: 9:33pm
