Why does my heat taper off?
Postby tims1957 [OP] » February 14th 2010, 4:40am
Im new to the forum and new to the astro safari world. I just bought a 2000safari with the travel Quest conversion. I drove it home friday night. 45 minute ride and by the time i got home there was no longer any heat. tempgage read about 170. Sat morning put in a new 195 tstat,topped off antifreeze. Blew hot ait like a champ. gage read about 190ish. Drove it to dinner sat night, the air coming from the vents slowly got cooler and cooler.gage never moved. Im baffled. If it matters it has rear heat and a/c. Any suggestions are appreciated! :shrug:
tims1957
Years of Membership: tims1957 has been a member for 10 full yearstims1957 has been a member for 10 full yearstims1957 has been a member for 10 full yearstims1957 has been a member for 10 full yearstims1957 has been a member for 10 full yearstims1957 has been a member for 10 full yearstims1957 has been a member for 10 full yearstims1957 has been a member for 10 full yearstims1957 has been a member for 10 full yearstims1957 has been a member for 10 full years
Extra Info: TravelQuest conv
Re: Why does my heat taper off?
Postby Astroplane » February 14th 2010, 5:14am
LastCat is right on about checking the valve. :clap:
I had to edit my original reply because I told you what to check for on a '99 Blazer. Different system.
You are asking about the front core? Is the rear blowing heat like it should? You might still have air in the system. If it is completely filled and it still tapers off, the front core or valve may be restricted. Also check the vacuum lines near the A/C accumulator going to the valve and vacuum reserve ball.
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full years
Extra Info: LT RWD
Postby Lastcat » February 14th 2010, 5:57am
Check your Heater Valve. I had the same problem, I could always get heat to the back heater, but the front would get colder after the van warmed up. I was shutting the fan off, after 5 mins turn it back on, and get about a minute of heat, then it got cold. That valve is on the passenger side, near the firewall. I took mine out, and it had a rubber stopper that came off the shaft and was plugging the outlet to the front heater, I didn't replace the valve yet, but just removed the stuck rubber stopper. Next summer, I will have to replace that valve.
Well that's one idea, you could have a few other problems.
LC
Lastcat
Years of Membership: Lastcat has been a member for 12 full yearsLastcat has been a member for 12 full yearsLastcat has been a member for 12 full yearsLastcat has been a member for 12 full yearsLastcat has been a member for 12 full yearsLastcat has been a member for 12 full yearsLastcat has been a member for 12 full yearsLastcat has been a member for 12 full yearsLastcat has been a member for 12 full yearsLastcat has been a member for 12 full yearsLastcat has been a member for 12 full yearsLastcat has been a member for 12 full years
Topics: 5
Postby tims1957 [OP] » February 14th 2010, 5:48pm
I checked it again this morning.Once the van warmed up i got luke warm air from the front vents. Cold air in the rear. Yesterday i had hot air from both at first. The front heater core has 2 lines going to it. Lower wich is bigger than the upper is hot,upper is cold. Maybe valve is partially open? allowing some heat?
Is there anywhere i can see a diagram of where all the hoses on that valve come and go to?
tims1957
Postby Astroplane » February 15th 2010, 5:08am
Take a look at the thread "No Rear Heat" in this forum.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby astro355 » February 15th 2010, 10:32am
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby Vinnie6 » February 16th 2010, 5:51am
I had the exact problem you are talking about - top heater core return hose cold. The rear heat was still working but slowly getting colder and colder. My problem was excessive sediment buildup in the dexcool, plugging the heater cores. Backflushing the heater core fixed it until it plugged up again (usually about three hours of run time). I finally licked it permanently when I had the entire system flushed out and replaced the coolant with propylene glycol instead of Dexcool. In my case the heater control valves were fine. What caused the sediment buildup in the dexcool? Air is what I am told. I suspect I had a bad radiator cap.
Vinnie6
Years of Membership: Vinnie6 has been a member for 11 full yearsVinnie6 has been a member for 11 full yearsVinnie6 has been a member for 11 full yearsVinnie6 has been a member for 11 full yearsVinnie6 has been a member for 11 full yearsVinnie6 has been a member for 11 full yearsVinnie6 has been a member for 11 full yearsVinnie6 has been a member for 11 full yearsVinnie6 has been a member for 11 full yearsVinnie6 has been a member for 11 full yearsVinnie6 has been a member for 11 full years
Topics: 13
Extra Info: LS RWD
Postby astroturf » February 27th 2010, 1:06am
Vinnie6 wrote:I had the exact problem you are talking about - top heater core return hose cold. The rear heat was still working but slowly getting colder and colder. My problem was excessive sediment buildup in the dexcool, plugging the heater cores. Backflushing the heater core fixed it until it plugged up again (usually about three hours of run time). I finally licked it permanently when I had the entire system flushed out and replaced the coolant with propylene glycol instead of Dexcool. In my case the heater control valves were fine. What caused the sediment buildup in the dexcool? Air is what I am told. I suspect I had a bad radiator cap.
Vinnie, What type of coolant did you go with? Thanks, Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Vinnie6 » February 27th 2010, 3:39am
astroturf wrote:Vinnie, What type of coolant did you go with? Thanks, Jim
Amsoil, mixed 50/50 with distilled water.
Vinnie6
Topics: 13
Extra Info: LS RWD
Return to Climate Control
It is currently October 28th 2020, 11:20pm
Climate Control Forum
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
Date: Oct 17 '20
Time: 7:13pm
Date: Oct 03 '20
Time: 8:08pm
charlesives95
in Climate Control
Comments: 13
Date: Sep 25 '20
Time: 3:38am
charlesives95
in Climate Control
Comments: 13
Date: Sep 24 '20
Time: 9:00pm
