No high speed fan
No high speed fan
Postby smokamoto [OP] » August 23rd 2014, 4:50am
I admit I'm too busy to search this (and I just saw a post about no high speed fan-but didn't read it doh!) so here it is...new AC Delco blower resistor & connector pigtail harness, cleaned up one burnt connector on the fan speed switch, and now all fan speeds work except high. Symptom was intermittent operation of fan on all speeds...I know, go search...
smokamoto
1998 Astro 2WD 8 passenger
120k miles
Previous Astros-'95 passenger, '90 passenger
smokamoto
Years of Membership: smokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full yearssmokamoto has been a member for 13 full years
Alias (AKA): smokamoto
Extra Info: 8 passenger RWD
Re: No high speed fan
Postby Lumpy » August 23rd 2014, 5:44am
I really don't know the answer, esp since you've replaced the usual suspect parts. But the good part about those who suggest "Go look it up" is that it's already looked up and there should be about five "related topics" at the bottom of this very thread.
I know it's a common problem. One that I haven't experienced though. So several people have already figured it out.
Years of Membership: Lumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full years
Postby smokamoto [OP] » August 23rd 2014, 6:58am
Thanks Lump...I'm searching now!
smokamoto
120k miles
smokamoto
Postby smokamoto [OP] » August 23rd 2014, 11:41pm
I checked the wiring diagram then found I have 12 volts to the blower resistor for the lower speeds but 0 volts to the orange wire that energizes the hi speed circuit. So I suspect the burned connection at the fan switch that I cleaned up has more issues, I'll do more troubleshooting on the switch. Gotta be it...
smokamoto
120k miles
smokamoto
Postby Lumpy » August 24th 2014, 12:26am
smokamoto wrote:I checked the wiring diagram then found I have 12 volts to the blower resistor for the lower speeds but 0 volts to the orange wire that energizes the hi speed circuit...
Orange, in OEM wiring, is HOT ALWAYS. If you're not getting voltage there then it might be as simple as the fuse that supplies that wire. I think(?) 30A in your year, marked HVAC.
Postby smokamoto [OP] » August 24th 2014, 6:44am
Fuse ok, and the blower wouldn't work on any speed if blown, correct?
smokamoto
120k miles
smokamoto
Postby chevy57bert » August 24th 2014, 7:54am
Only high speed.. resistor fail
Only lower speeds.. blown fuse
chevy57bert
Section Moderator
Section Moderator
Firing on 8 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 12 full yearschevy57bert has been a member for 12 full yearschevy57bert has been a member for 12 full yearschevy57bert has been a member for 12 full yearschevy57bert has been a member for 12 full yearschevy57bert has been a member for 12 full yearschevy57bert has been a member for 12 full yearschevy57bert has been a member for 12 full yearschevy57bert has been a member for 12 full yearschevy57bert has been a member for 12 full yearschevy57bert has been a member for 12 full yearschevy57bert has been a member for 12 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Postby Lumpy » August 24th 2014, 1:41pm
I'm tracing the schematic in my 89 FSM. Mine appears to be wired differently than your year model. I don't have an orange wire on my resistor block.
But I think(?) what Bert suggests is universally correct across models.
+12v travels direct to the fan motor when in HIGH.
+12v travels to the resistor block and then to the fan when the selector is in any position other than HIGH.
The changeover occurrs at the HIGH blower relay on the firewall. With the fan switch in "Other than HIGH" the relay is not engaged and sends +12v to the resistor block. With the fan switch on HIGH, relay engages, sends +12v direct to the fan via the PURPLE wire.
SO - Might just be that your high blower relay is not functioning. Perhaps the relay itself, perhaps the connection or wiring to the relay. My relay went bad once.
Test the relay with +12v on [52], GROUND or -12v on [152]
Postby smokamoto [OP] » August 25th 2014, 6:13am
Lump is THE MAN...blown 30 amp giant fuse under the hood...DOH check the easy stuff first!!!
Thank you Lumpy!
smokamoto
120k miles
smokamoto
Postby Lumpy » August 25th 2014, 6:41am
Lumpy wrote:
...The changeover occurrs ...
Occurrrs, Ocurrs, Ocuurss...happens
Return to Climate Control
It is currently July 26th 2021, 1:48am
Climate Control Forum
Attached by: paulbot
paulbot
in Climate Control
Date: Jul 11 '21
Time: 8:00pm
the_bruce
in Climate Control
Date: Jul 08 '21
Time: 7:45pm
OldSchoolNoe
in Climate Control
Date: Jul 05 '21
Time: 4:56am
OldSchoolNoe
in Climate Control
Date: Jun 30 '21
Time: 10:53pm
OldSchoolNoe
in Climate Control
Date: Jun 30 '21
Time: 3:09am
