Another Vent control issue
Postby Neb127 [OP] » December 30th 2014, 7:44pm
Not sure if the picture will help - but I have the issue with the blower only blowing through the defrost vents - from what I've read this is prpbably a vacuum issue ?
This T- Junction sits on the left side of the engive and the tubes dissappear down below - but the rubber coaitng seems rotten and although I haven't puled or poked to much - my question is, am I in the right area ?
34250
1999 Chevy LT AWD, no mods - Yet
Neb127
Years of Membership: Neb127 has been a member for 6 full yearsNeb127 has been a member for 6 full yearsNeb127 has been a member for 6 full yearsNeb127 has been a member for 6 full yearsNeb127 has been a member for 6 full yearsNeb127 has been a member for 6 full years
Topics: 12
Images: 20
Extra Info: LT
  • Ceiling Vent?
    by Psyckosama » November 9th 2020, 9:59am in Climate Control
    Last post by Psyckosama View the latest post
    November 10th 2020, 12:38pm
  • Trouble with A/C / heat blower fan control on our '95.
    by 95AstroLT » January 9th 2021, 12:16am in Climate Control
    Last post by 95AstroLT View the latest post
    January 9th 2021, 9:23pm
    February 25th 2021, 11:24am
Re: Another Vent control issue
Postby Lumpy » December 30th 2014, 8:03pm
[broken record mode]
Don't waste time dicking around with trying to DIAGNOSE a vacuum problem. Simply REPLACE all the vacuum lines. They need it every few years anyway. Costs maybe ten bucks to do them all. THEN see if there's some other problem-prblum-prvblam.
Postby zipwood » August 26th 2015, 1:15am
2003 Safari. I just replaced the RAD and it all seems to be working OK. I get heat and A/C but obviously I screwed up the Vaccuum Lines --- I found some line just hanging and stuck it on what I thought was it's home - but nope . all i get is defrost.
This Specific Van has always had an issue with WITH AIR FLOW, even before this latest issue. I swear it has been screwed since day one.
Anyhow , I see lumpy recos buying all the hoses (no problem) but a usefull Schematic Link may sure help
thanks in advance
zipwood
Years of Membership: zipwood has been a member for 5 full yearszipwood has been a member for 5 full yearszipwood has been a member for 5 full yearszipwood has been a member for 5 full yearszipwood has been a member for 5 full years
Images: 15
Extra Info: 4.3l V6 rwd
Postby Corsemoto » August 26th 2015, 1:27am
It's in the sticky at the top o' the page...
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby Lumpy » August 26th 2015, 2:30am
If you think a schematic "may sure help" then you're not looking at the situation the same way I do.
Imagine you had a garden hose. Connects to the house on one end, to the nozzle on the other. If you bought a new hose to replace it, would you need a schematic?
View EACH vacuum hose the same way. NEVER disconnect any more than ONE END of any hose. Grab any hose. Disconnect ONE end of that hose. Plug on new, very long piece of replacement hose. Now follow the old hose to it's terminus. Pull that, snip the new hose to length, plug it in. There's one hose replaced. Repeat a dozen times and you've got all of them replaced.
No need for a schematic. The hose is in your hand. It only goes from HERE to THERE, both places you can see. That's much simpler and intuitive than looking at a drawing of an engine that may or may not look exactly like yours.
Return to Climate Control
It is currently February 25th 2021, 11:24am
Climate Control Forum
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
in Climate Control
Comments: 14
Date: Feb 17 '21
Time: 2:47pm
Attached by: SportsBoy
SportsBoy
in Climate Control
Date: Jan 10 '21
Time: 5:10am
SportsBoy
in Climate Control
Date: Dec 31 '20
Time: 4:43am
SportsBoy
in Climate Control
Date: Dec 29 '20
Time: 5:46am
Users browsing this forum: Google Adsense [Bot] and 8 guests
