sooooo....after much reading and help from yall....i think i've got my oil adapter leak fixed....yall are vaaantastic!!!
now onto the next issue
no rear heat at all only cold air blows, no footwell heat, but it blows into the underside of dash in the black "ductwork" in passenger footwell just not out of the vent at all. Defrost blows strong but the blower motor hums differently in defrost.
so after alot of reading i will start with:
1. "No heat/air/vent control issues? Start here GenII" thread - started reading this and looks like i need to trace some vaccuum lines
2. flush the coolant...probably good idea since i bought it used and don't know if this has been done...coolant looks green
3. bypass the heater control valve to see if i get rear heat
i do have very hot heat from dash vents, but it does cut out occasionally and blow warm for a second (maybe when i hit a bump in the road)
i shall continue researching for now.....any other advice?....point me to any certain thread on this?
thanks guys and girls
