Vacuum Tank 1991 astro
Postby griff714 [OP] » May 14th 2010, 3:55am
Does anyone know where the vacuum tank for feeding the heater/AC switch is on a 1991 Astro V6?
I have a service manual but all it says is cowl. Would this be behind the wiper blades?
It's hard to see there are so many wires and vacuum lines.
Thanks
griff714
griff714
Years of Membership: griff714 has been a member for 10 full yearsgriff714 has been a member for 10 full yearsgriff714 has been a member for 10 full yearsgriff714 has been a member for 10 full yearsgriff714 has been a member for 10 full yearsgriff714 has been a member for 10 full yearsgriff714 has been a member for 10 full yearsgriff714 has been a member for 10 full yearsgriff714 has been a member for 10 full yearsgriff714 has been a member for 10 full years
Extra Info: 4.3L V6
Re: Vacuum Tank 1991 astro
Postby chevy57bert » May 14th 2010, 11:39am
on a 92 it`s on the pass side fenderwell at the front.
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Postby griff714 [OP] » May 14th 2010, 1:47pm
Thanks chevy57bert but it's not there. That's where my windshield washer and radiator overflow are and it's not behind them or on the other fender.
I can't find the vacuum source from the engine either. I can see where the PVC gets vacuum. It should be at the base of the throttle body or on top of the intake manifold. Right?
I don't have any vacuum going to my heater/AC switch that's why I'm looking for the source or the vacuum can.
Thanks
griff714
griff714
Extra Info: 4.3L V6
Postby chevy57bert » May 14th 2010, 2:18pm
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby griff714 [OP] » May 14th 2010, 4:11pm
Thanks chevy57bert at least I know what it looks like. I didn't see anything like that on the engine side but I think it might be behind the main heater plenum coming in from the blower motor. I can see the edge of a couple flying saucer shaped thing I guess are the vent door actuators.
Thanks again
Griff714
griff714
Extra Info: 4.3L V6
Postby chevy57bert » May 14th 2010, 4:31pm
griff714 wrote:Thanks chevy57bert at least I know what it looks like. I didn't see anything like that on the engine side but I think it might be behind the main heater plenum coming in from the blower motor. I can see the edge of a couple flying saucer shaped thing I guess are the vent door actuators.
Thanks again
Griff714
Your welcome and you could use the search button.
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby LEVE » May 14th 2010, 5:08pm
This pic is for an 89, but it should be similar to your van. The tank is located between the passenger side inner-fender and the engine, just behind the bumper area...
LEVE
Years of Membership: LEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby griff714 [OP] » May 14th 2010, 10:43pm
Thanks everybody I'll check that out later or tomorrow.
griff714
griff714
Extra Info: 4.3L V6
Postby chevy57bert » May 14th 2010, 11:03pm
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby griff714 [OP] » May 14th 2010, 11:52pm
Thanks again chevy57bert. A picture is is worth a 1000 words.
It has to be in one of those places.I have to work tomorrow but I'll check it out over the weekend and you have a good weekend too.
griff714
griff714
Extra Info: 4.3L V6
Postby Dirk » May 18th 2010, 1:10pm
It's sits below the coolant reservoir, about 4 inches above the sub frame.
1985 Astro conversion, engine type N 4.3 4BBL
If you can't fix it with a hammer you've got an electrical problem!
Parts are cheap breakdowns expensive.
Don't worry about miles per gallon, worry about smiles per gallon!
Dirk
Firing on 8 Cylinders (L1)
Years of Membership: Dirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full years
Images: 11
Extra Info: 4.3L 4BBL
Postby griff714 [OP] » May 18th 2010, 2:18pm
Thanks Dirk I'll check it out when the rain stops.
I appreciate all the help I've gotten from everyone.
griff714
griff714
Extra Info: 4.3L V6
Postby chevy57bert » May 18th 2010, 2:53pm
griff714 wrote:Thanks Dirk I'll check it out when the rain stops.
griff714
Working on the stro.. I thought I make a picture.. do you like it Griff714 ??? :rofl:
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Return to Climate Control
It is currently October 29th 2020, 3:27am
Climate Control Forum
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
Date: Oct 17 '20
Time: 7:13pm
Date: Oct 03 '20
Time: 8:08pm
charlesives95
in Climate Control
Comments: 13
Date: Sep 25 '20
Time: 3:38am
charlesives95
in Climate Control
Comments: 13
Date: Sep 24 '20
Time: 9:00pm
cron
