Blower Motor very low speed
Postby woodhaven22 [OP] » May 16th 2010, 11:24pm
Hello,
We have a 2001 AWD Astro van that the blower motor only runs are very low speed. At times, it doesnot run at all. This is the resistor relay. Where is this located?
Thanks
Clinton
woodhaven22
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: woodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full years
Topics: 34
Re: Blower Motor very low speed
Postby astroturf » May 17th 2010, 1:15am
woodhaven22 wrote:Hello,
Thanks
Clinton
This PDF will give you an idea of where to find it. The PDF covers replacement, but give yours a once over first. Could be a loose connection, a bad solder joint on the board, or something else. Like I said have a look. Hope it helps, Jim
AstroSafariBlowerResistor_EN.pdf
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby AllWheelingDenise » May 20th 2010, 2:25am
This is a surprise! I was thinking all along it's the blower motor.. and guess what? the blower motor is cheaper then the resistor? :screaming: Guess I better ck the resistor first.
AllWheelingDenise
Years of Membership: AllWheelingDenise has been a member for 12 full yearsAllWheelingDenise has been a member for 12 full yearsAllWheelingDenise has been a member for 12 full yearsAllWheelingDenise has been a member for 12 full yearsAllWheelingDenise has been a member for 12 full yearsAllWheelingDenise has been a member for 12 full yearsAllWheelingDenise has been a member for 12 full yearsAllWheelingDenise has been a member for 12 full yearsAllWheelingDenise has been a member for 12 full yearsAllWheelingDenise has been a member for 12 full yearsAllWheelingDenise has been a member for 12 full yearsAllWheelingDenise has been a member for 12 full years
Topics: 13
Extra Info: 1998 sle
Return to Climate Control
It is currently November 24th 2020, 9:47am
Climate Control Forum
Date: Nov 19 '20
Time: 9:33pm
Date: Nov 18 '20
Time: 5:15pm
doogaloo
in Climate Control
Comments: 9
Date: Nov 09 '20
Time: 11:08pm
Date: Oct 31 '20
Time: 9:45pm
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
Users browsing this forum: Yandex [Bot] and 5 guests
