how to R&R oil and transmission cooler lines from radiator
Postby rev_les [OP] » June 10th 2010, 5:12am
I didn't take pics, but to summarize the oil cooler and transmission cooler line removal and replacement, take a small curved pick, and a small flat blade screwdriver..
On the oil cooler lines, take the pick, and use it to push the end of the clip enough to get a gap large enough to get the screwdriver under the edge of it near the center. Once you are at this point, put a finger over the clip to keep it from flying astray ( safety glasses might be good to have on for this) Pull the clip with the screwdriver toward your finger, and catch it when it pops off, then pull the oil line out of the hole. Repeat for the other line. The transmission cooler lines use the same procedure, except there's a cover over the clips, just slide it back out of the way. To reinstall, put the clips back in the grooves ( there are 4 slots in the screw in adapter that the lines clip in to) place the line up against it as far as you can, and push it in until it latches. A LIGHT tap with a plastic mallet might assist. I just wanted to post this while it's relatively fresh in my head, (even though I was half asleep doing it) :D
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
  • Rear AC removal Block lines
    by gmcjunk » February 5th 2021, 5:41pm in Climate Control
    Last post by gmcjunk View the latest post
  • REAR WIPER AND A/C SWITCH PROBLEM
    by crittermo » December 8th 2020, 10:40pm in Climate Control
    December 10th 2020, 7:49pm
    April 18th 2021, 4:51pm
Re: how to R&R oil and transmission cooler lines from radiat
Postby Matrixx » June 10th 2010, 7:34am
I'm sure others will benefit from your experience rev_les, thanks for posting it.:)
Matrixx
Return to Climate Control
It is currently April 18th 2021, 4:51pm
Climate Control Forum
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
Toskavat
in Climate Control
Comments: 17
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
in Climate Control
Date: Feb 17 '21
Time: 2:47pm
Users browsing this forum: Google [Bot] and 19 guests
cron
