At any rate, several hours of searching this great forum helped track down my A/C problem to either the blower motor, the resistor, or the connector. Initially, neither the A/C compressor or the blower motors would kick in. After replacing a blown fuse, the compressor and rear A/C works great on all settings, but there's still no air coming out of the front vents on any of the fan settings. As you can see, the connector at the resistor is burnt and will most likely need replacement. Is this a junkyard part, or can I find a replacement at a dealership?
Also, what tests can I perform to determine if the blower motor and resistor also need replacement?
On a different subject, I found this wire dangling near the steering column. What is it supposed to attach to?
