Blower motor switch not working
Postby wreams [OP] » July 19th 2010, 4:11am
1997 safari, OK so Ive put in a new resistor pack, connectors are all good, blower motor is good, switch dosent work.
so i have a constant 12v source to the resistor, but the other wires coming from the switch only have like 5v.
so when the switch is on low one of the wires will have 5v, when its turned up a different wire will have 5v. so is this normal or should it be 12v? when i jump the smaller wires from the switch with 12v it works so Do i need a new switch? how do i replace it if so?
any help is appreciated
wreams
Years of Membership: wreams has been a member for 10 full yearswreams has been a member for 10 full yearswreams has been a member for 10 full yearswreams has been a member for 10 full yearswreams has been a member for 10 full yearswreams has been a member for 10 full yearswreams has been a member for 10 full yearswreams has been a member for 10 full yearswreams has been a member for 10 full yearswreams has been a member for 10 full years
Re: Blower motor switch not working
Postby ASTRODAN » July 20th 2010, 12:27am
THEY SHOULD BE 12 AT FOUR OF THEM AT THE DIFFERENT SWITCH POSITIONS ONE SHOULD BE A GROUND AND ONE SHOULD HAVE 12 V AT ALL TIMES
98 astro awd hightop waldoch conversion-origanal motor,trans.diff,tranfer case,frt. diff. got it with 100k miles in 7/05 now has 252k and purrs like a kitten
ASTRODAN
Years of Membership: ASTRODAN has been a member for 10 full yearsASTRODAN has been a member for 10 full yearsASTRODAN has been a member for 10 full yearsASTRODAN has been a member for 10 full yearsASTRODAN has been a member for 10 full yearsASTRODAN has been a member for 10 full yearsASTRODAN has been a member for 10 full yearsASTRODAN has been a member for 10 full yearsASTRODAN has been a member for 10 full yearsASTRODAN has been a member for 10 full years
Extra Info: 4.3AWD HIGHTOP
Return to Climate Control
It is currently November 27th 2020, 8:51am
Climate Control Forum
Date: Nov 19 '20
Time: 9:33pm
Date: Nov 18 '20
Time: 5:15pm
doogaloo
in Climate Control
Comments: 9
Date: Nov 09 '20
Time: 11:08pm
Date: Oct 31 '20
Time: 9:45pm
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
Users browsing this forum: Yandex [Bot] and 7 guests
