I have a 1996 GMC Safari with a few Heater Vent Control issues.
Please excuse my descriptions, as here in the UK we use different words to describe things, and I am struggling with some of the terminolgy that you guys are using - Words like Panel Blend are leaving me more confused than my fault.
Anyhow, here goes . . . . .
Initially my truck was on the Defrost screen and freeze your feet setting, and after reading some excellent guides on here, I have replaced the broken rigid vacuum pipe that comes from the engine, and also replaced the rubber pipe down to the Vacuum sphere under the bonnet (Hood?).
I now have Vent controls in a few more settings except the ones that point directly at you. The top window setting comes on and off as it should, the passenger feet come on when it should, and the little actuator by the passenger door operates as it should (now that I have fixed that one too)
But from here, I am now stuck.
On the passenger side, I cannot get anything out of the dash vents that are either side of the airbag.
On the drivers side, the one pointing at the mirror is ok, but I have nothing either side of the instrument cluster, nor the one located underneath the steering column.
Any thoughts please?
