Need help to find another rear axle for my -89Astro
Postby NorwegianAstro [OP] » January 3rd 2009, 2:45am
Hi every one
I have a problem. I would like to put wider wheels on my -89 astro
This is my Van
Here are my wheels 15"x10"
I need a rear axle from a GM car with a V8 engine, 10bolt rear axle? That is shorter than the original Astro axle. Can any one help out to find a rear axle to my van? I want my wheels under the original fender...
As you can see here, plenty of room on the inside...
But the axle is too wide...
My axle are 149,7cm between brakedrums...
1990 Chevrolet Astro 4,3l V6
1989 Chevrolet Silverado 4x4 Pickup (sold)
1988 Pontiac Fiero Formula 2,8l, aut.
1971 Chevrolet Camaro SS 5,7l ZZ4 TH700 aut.
1971 VW Beach Buggy
1963 VW Beetle 1,7l Injection
NorwegianAstro
Years of Membership: NorwegianAstro has been a member for 12 full yearsNorwegianAstro has been a member for 12 full yearsNorwegianAstro has been a member for 12 full yearsNorwegianAstro has been a member for 12 full yearsNorwegianAstro has been a member for 12 full yearsNorwegianAstro has been a member for 12 full yearsNorwegianAstro has been a member for 12 full yearsNorwegianAstro has been a member for 12 full yearsNorwegianAstro has been a member for 12 full yearsNorwegianAstro has been a member for 12 full yearsNorwegianAstro has been a member for 12 full yearsNorwegianAstro has been a member for 12 full years
Re: Need help to find another rear axle for my -89Astro
Postby astro355 » January 3rd 2009, 6:51am
Hello,
I have been looking into this for a while. I am going to tube my van this spring and need to find a skinny rear axle to accommodate my project. Only problem is that I couldn't find one. Thru all of my research, the 10 bolt in the astro/safaris are the narrowest GM makes. Now there is a hole in some of my research involving S-10s. From what I could find, S-10s were the same or wider than that of our vans. I have heard from other people I talked to about it that S-10s do come with narrower rear ends than our vans but I never found any information to back that claim up.
Sorry, I know that doesn't really help much. What I have had to due with my van is install a Ford 9 inch rearend (also be done in the spring). I was lucky to find one off of a 1964 Falcon and its only 52" wide (132 cm).
Any chance you can get wheels with different backspacing?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby hangmans8 » April 2nd 2009, 5:29pm
S10 diff's are aboujt 5" narrower then astros. the best and most direct diff is a 9" out of late 70's and early 80's ford e-150 vans, do to the center section offset. the diff is about 2" narrower
hangmans8
Years of Membership: hangmans8 has been a member for 12 full yearshangmans8 has been a member for 12 full yearshangmans8 has been a member for 12 full yearshangmans8 has been a member for 12 full yearshangmans8 has been a member for 12 full yearshangmans8 has been a member for 12 full yearshangmans8 has been a member for 12 full yearshangmans8 has been a member for 12 full yearshangmans8 has been a member for 12 full yearshangmans8 has been a member for 12 full yearshangmans8 has been a member for 12 full yearshangmans8 has been a member for 12 full years
Alias (AKA): hangman
Postby Farmer » April 2nd 2009, 5:38pm
different backspacing on the wheels would be the easiest fix, or find someone that can narrow down your stock diff. then you would need custom axle shafts made to fit the narrower diff.
'86 Astro shorty, rwd, 8 pass, 4.3 v6, Auto trans
'81 Bronco, 6" lift, 35" tires, Solid axle conversion
RESPECT THE VAN!!!
Farmer
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Farmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full years
Postby Skorstad85 » October 19th 2009, 9:00pm
There is a '88 Astro in Sweden with 515/45-15 tyres, however that rear axle is severely custom-built,
a shortened 12-bolt GM with LSD and Strange-axles. Expensive perhaps?
If you can find Bilsport nr 13/09 it's on page 32.
Don't have a scanner, otherwise I'd scan the pages for you.
Skorstad85
Years of Membership: Skorstad85 has been a member for 11 full yearsSkorstad85 has been a member for 11 full yearsSkorstad85 has been a member for 11 full yearsSkorstad85 has been a member for 11 full yearsSkorstad85 has been a member for 11 full yearsSkorstad85 has been a member for 11 full yearsSkorstad85 has been a member for 11 full yearsSkorstad85 has been a member for 11 full yearsSkorstad85 has been a member for 11 full yearsSkorstad85 has been a member for 11 full yearsSkorstad85 has been a member for 11 full years
Extra Info: CL 4.3 RWD
Postby astrovan98 » October 27th 2009, 1:52am
Astro rear axles are around 66 1/2" from wheel mounting face to wheel mounting face (brake drum at studs).
The S10 units are 54" wide. Problem is the Astro center section is quite offset to the passenger side, but the S10 is centered on the tubes.
I was researching this, and had an S10 rear axle, but it would have been more touble to lengthen one tube and have a new axle made to lengthen the drivers side.
I ended up shortening (for a second time) my already narrowed housing. Moser Engineering made my axles for the first narrowing, and had the foresight to make the shafts a constant diameter, so they could be shortened again. It worked well and I stuffed some 20 X 10's in the fenderwells, but not before I fabricated a new subframe and relocated all the suspension inboard.
Sorry guy's, there doesn't seem to be a direct fit housing for our application. You have to have one made, or make it yourself.
astrovan98
Years of Membership: astrovan98 has been a member for 12 full yearsastrovan98 has been a member for 12 full yearsastrovan98 has been a member for 12 full yearsastrovan98 has been a member for 12 full yearsastrovan98 has been a member for 12 full yearsastrovan98 has been a member for 12 full yearsastrovan98 has been a member for 12 full yearsastrovan98 has been a member for 12 full yearsastrovan98 has been a member for 12 full yearsastrovan98 has been a member for 12 full yearsastrovan98 has been a member for 12 full yearsastrovan98 has been a member for 12 full years
Return to Lowered Suspension
It is currently April 12th 2021, 8:02am
Lowered Suspension Forum
Lowered SuspensionLowering Suspension, Slamming, Flip-kits, Spindles, Shackles, Hangers, Lowering Coils, Air Bags, Hydraulics.
To create a new topic in Lowered Suspension, click this button:
Date: Mar 22 '21
Time: 1:57pm
TBLBill
Date: Aug 26 '19
Time: 10:01pm
LateGreat
Date: Aug 25 '19
Time: 11:18am
Comments: 31
Date: Aug 10 '19
Time: 3:02pm
Attached by: markmitch
Comments: 31
Date: Dec 07 '18
Time: 7:35pm
Users browsing this forum: Google Adsense [Bot] and 14 guests
