Stiffening Rear Suspension
Postby Deadly Sones [OP] » September 2nd 2013, 12:50am
Hey guys,
I have a 91 Safari Cargo van. 4.3L. I'm using it as a car audio competition vehicle. I currently have the "composite" leaf looking spring.
I have been told there are kits that I can just "bolt on". Are these any good? I'm talking an additional 2000+lbs back there. I have already added 186ft of 1.5" steel tube for the cage and the factory suspension has held up well. However, once the 11 sheets of 1" MDF, 8 sheets of 3/4" MDF, 8 15" subs, amps and 10 batteries are in. I'm gonna need MUCH more.
I was also thinking of switching out the "composite" springs for the OS leaf springs. Good idea? Where might I get a set that would fit? Are they the same as on a burban? My friend is scrapping one.
I'm open to all suggestions on how to properly beef up this rear end.
Deadly Sones
Years of Membership: Deadly Sones has been a member for 8 full yearsDeadly Sones has been a member for 8 full yearsDeadly Sones has been a member for 8 full yearsDeadly Sones has been a member for 8 full yearsDeadly Sones has been a member for 8 full yearsDeadly Sones has been a member for 8 full yearsDeadly Sones has been a member for 8 full yearsDeadly Sones has been a member for 8 full years
Van Model Year: 1991
Extra Info: 4.3L
Re: Stiffening Rear Suspension
Postby Jasen » September 2nd 2013, 1:41am
2k is a lot, i carry 1500lbs and that has my rear springs maxed out.
overland makes glass to steel conversion kits http://www.overlandvans.com/
or you can build it from ATS, they carry HD and XHD springs http://www.autoandtrucksprings.com/
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Deadly Sones [OP] » September 2nd 2013, 1:51am
Thanks for the links. I'll def look up what they have.
These are suppose to work with the composite (mono) springs...
http://www.carid.com/1991-gmc-safari-su ... 13246.html
Are they any good? It might not be over 2K lbs but damn near 1500+ I'm sure.
Deadly Sones
Extra Info: 4.3L
Postby 97cargocrawler » September 2nd 2013, 4:38am
I suggest you make a custom spring pack and beef up your axle as well with a weld on truss. Then do the 11" drum and 3500 series caliper upgrades.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby Deadly Sones [OP] » September 10th 2013, 2:27pm
Thanks for the mod info. I'll def look into beefing up the drums. Does it require a different axle? Do you possibly have a link to where I can buy them?
Deadly Sones
Extra Info: 4.3L
Return to Lowered Suspension
It is currently April 13th 2021, 6:12pm
Lowered Suspension Forum
Lowered SuspensionLowering Suspension, Slamming, Flip-kits, Spindles, Shackles, Hangers, Lowering Coils, Air Bags, Hydraulics.
To create a new topic in Lowered Suspension, click this button:
Date: Mar 22 '21
Time: 1:57pm
TBLBill
Date: Aug 26 '19
Time: 10:01pm
LateGreat
Date: Aug 25 '19
Time: 11:18am
Comments: 31
Date: Aug 10 '19
Time: 3:02pm
Attached by: markmitch
Comments: 31
Date: Dec 07 '18
Time: 7:35pm
