tubular control arms
Postby mrbarky [OP] » January 25th 2010, 9:28pm
are they the same as s-10s or does someone make them for the astro i have a 92 2 wheel drive I have some serious camber issues just wanting to correct and yes its bagged
mrbarky
Years of Membership: mrbarky has been a member for 11 full yearsmrbarky has been a member for 11 full yearsmrbarky has been a member for 11 full yearsmrbarky has been a member for 11 full yearsmrbarky has been a member for 11 full yearsmrbarky has been a member for 11 full yearsmrbarky has been a member for 11 full yearsmrbarky has been a member for 11 full yearsmrbarky has been a member for 11 full yearsmrbarky has been a member for 11 full yearsmrbarky has been a member for 11 full years
Extra Info: bodydropped
Re: tubular control arms
Postby astroturf » January 30th 2010, 5:48am
What are your camber readings inflated?
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby astro355 » January 30th 2010, 6:47am
Are you talking about too much negative or positive camber?
Are the stock adjustments not significant enough for your needs?
Any feedback would be great and pics would be better.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby mrbarky [OP] » January 30th 2010, 9:46pm
i have too much negative camber going to try to pull shims when this weather gets better dont have a pic because its snowing its butt off
mrbarky
Postby astroturf » January 31st 2010, 2:16am
Maybe I should have been more clear. What are your current camber specs when on the rack with the alignment equipment hooked up? What are the readings?
astroturf
Topics: 112
Postby mrbarky [OP] » January 31st 2010, 1:17pm
I have not been to a shop yet I just bought this about a month ago and havent been able to take it to a shop the guy before me sectioned the upper control arms that was the reason i wanted to know about tubular ones because not sure if they were done correctly but I have found some at Airbagit.com first thing im going to do is pull some shims and see if I can get it close and then It will be off to a shop for an alignment but if all else fails I'll be getting the ones from them
mrbarky
Postby mattconrad » February 18th 2010, 3:07am
STAY AWAY FROM AIRBAGIT.COM, THEY ARE JUNK
mattconrad
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: mattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full yearsmattconrad has been a member for 13 full years
Topics: 12
Return to Lowered Suspension
It is currently February 25th 2021, 9:27am
Lowered Suspension Forum
Lowered SuspensionLowering Suspension, Slamming, Flip-kits, Spindles, Shackles, Hangers, Lowering Coils, Air Bags, Hydraulics.
To create a new topic in Lowered Suspension, click this button:
TBLBill
Date: Aug 26 '19
Time: 10:01pm
LateGreat
Date: Aug 25 '19
Time: 11:18am
Comments: 31
Date: Aug 10 '19
Time: 3:02pm
Attached by: markmitch
Comments: 31
Date: Dec 07 '18
Time: 7:35pm
Comments: 31
Date: Dec 03 '18
Time: 1:39am
