How Can I do this???
Postby dieselnut04 [OP] » April 6th 2010, 4:11pm
[youtube]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/yIJRPktkjMo&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/yIJRPktkjMo&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/youtube]
I want my 93 laid out like this. i have all the bags, tanks, using the ac pump as a compressor what else???
dieselnut04
Years of Membership: dieselnut04 has been a member for 10 full yearsdieselnut04 has been a member for 10 full yearsdieselnut04 has been a member for 10 full yearsdieselnut04 has been a member for 10 full yearsdieselnut04 has been a member for 10 full yearsdieselnut04 has been a member for 10 full yearsdieselnut04 has been a member for 10 full yearsdieselnut04 has been a member for 10 full yearsdieselnut04 has been a member for 10 full yearsdieselnut04 has been a member for 10 full years
Re: How Can I do this???
Postby chevy57bert » April 6th 2010, 5:17pm
Look here. it`s sounds easy, but is it??? :whistle:
gallery2.php?g2_itemId=349
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Postby dieselnut04 [OP] » April 6th 2010, 10:41pm
no no i know its not gonna be easy to lay rockers on 22's. do i need spindels? or can i just z the frame in the front and lower the motor mounts? i can do all the fab work myself. also where can i get a good steel rollpan and other goodies???
dieselnut04
Postby scr8pnyota » April 6th 2010, 11:43pm
First you need a sawzall, lots of blades, beer, and some good friends to cut up the body.I would do a rear link set up and front upper and lower C arms if you want 22s. body dropped astros are sick well worth all the work
scr8pnyota
Years of Membership: scr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full years
Images: 3
Postby chevy57bert » April 7th 2010, 10:26am
if you go so low. you also have cut up the rear floor and wheeltubes.
go to 2/4 link, change the gastank, mount airbags. shocks.
the easy way... flipkit, but then you ain`t get low enough to spark the pavement ..
in front you can use 2 inch dropped spindles, airbags.
search a place to mount the shocks , and cut-up the wheeltubes (22inch)
But search the forum for bagged astro/safari`s
there are a lot of pictures here.
Gr Bertjuh
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby onelowstro » May 9th 2010, 5:26am
I see that u want to bodydrop your astro. That is a whole lot of work. Go to youtube and check out my lateless clip.
onelowstro
Years of Membership: onelowstro has been a member for 11 full yearsonelowstro has been a member for 11 full yearsonelowstro has been a member for 11 full yearsonelowstro has been a member for 11 full yearsonelowstro has been a member for 11 full yearsonelowstro has been a member for 11 full yearsonelowstro has been a member for 11 full yearsonelowstro has been a member for 11 full yearsonelowstro has been a member for 11 full yearsonelowstro has been a member for 11 full yearsonelowstro has been a member for 11 full years
Topics: 9
Postby 1992RS » May 9th 2010, 6:25am
Isnt there a whole build on here i think its by ratstro did the tubs in back sit about two inches off the ground ??
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Years of Membership: 1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years
Topics: 38
Alias (AKA): tony
Extra Info: RS 4.3v rwd
Postby chevy57bert » May 9th 2010, 1:11pm
onelowstro wrote:I see that u want to bodydrop your astro. That is a whole lot of work. Go to youtube and check out my lateless clip.
Didn`t Know that..... great Vid Ray....
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Return to Lowered Suspension
It is currently December 4th 2020, 3:07am
Lowered Suspension Forum
Lowered SuspensionLowering Suspension, Slamming, Flip-kits, Spindles, Shackles, Hangers, Lowering Coils, Air Bags, Hydraulics.
To create a new topic in Lowered Suspension, click this button:
TBLBill
Date: Aug 26 '19
Time: 10:01pm
LateGreat
Date: Aug 25 '19
Time: 11:18am
Comments: 31
Date: Aug 10 '19
Time: 3:02pm
Attached by: markmitch
Comments: 31
Date: Dec 07 '18
Time: 7:35pm
Comments: 31
Date: Dec 03 '18
Time: 1:39am
