what steal leafsprings will fit?
Postby chevy57bert [OP] » April 7th 2010, 9:38pm
Working on the Van i discovered very good used fiberglass spring on both sides
Question : What steel springs can I use for `92 Rwd astro? (i use a flipkit)
There plenty of JY in the Netherlands but NO Astro.
I want go to steal because I drop a V-8 in the Car later this year.
We have here a lot GM pick-up`s / full size cars at the JY to choose from.
I have no problem to slightly modified the leafsprings.
will use a flipkit
Please help...........
Thanks Bertjuh
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Re: what steal leafsprings will fit?
Postby chevy57bert [OP] » April 9th 2010, 10:44pm
Anyone?
Are there replaceable steal leaf springs from other GM-cars I can use ??
Thanks Bertjuh
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby 1992RS » April 9th 2010, 10:52pm
From every thing I have heard there are no other springs that will work with out some modification, but if modification isnt a prob for you I would say take some measurements and hit the junkyard.. Good luck to you
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Years of Membership: 1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years
Topics: 38
Alias (AKA): tony
Extra Info: RS 4.3v rwd
Postby chevy57bert [OP] » April 9th 2010, 11:06pm
1992RS wrote:From every thing I have heard there are no other springs that will work with out some modification, but if modification isnt a prob for you I would say take some measurements and hit the junkyard.. Good luck to you
modification won`t be a problem Tony.
with what type of leafspring can i start?
I take some measurements , a friend has some surburban parts.
I look if they could be modified to work with.
But If anyone know where to start, Let me know..
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby 1992RS » April 9th 2010, 11:14pm
I would look at vehichles like s10 or sonomas I think a suburban would be to big but maybe not if its a 1500 series
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby chevy57bert [OP] » April 9th 2010, 11:54pm
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby 1992RS » April 10th 2010, 1:19am
So according to that site the s10/s15 up to 95 have the same dimensions as the 95+ astro van springs and from what I know the springs from a 1995+ astro will bolt onto a 1995and older as long as you have access to the mounting brackets I only bring this up because the purchase price of the brackets and s10 springs are cheaper then the conversion kit for the fiberglass springs right?
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby chevy57bert [OP] » April 10th 2010, 9:55am
Yeb. the Astro steel-leafsprings will fit on early models if you use the also front mounting.
But you can`t find 97+ astro`s over here at the JY. some early types if your lucky.
Pick-up parts enough at the USA Cars JY in the Netherlands.
Grtzz Bertjuh
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Return to Lowered Suspension
It is currently March 6th 2021, 8:26am
Lowered Suspension Forum
Lowered SuspensionLowering Suspension, Slamming, Flip-kits, Spindles, Shackles, Hangers, Lowering Coils, Air Bags, Hydraulics.
To create a new topic in Lowered Suspension, click this button:
TBLBill
Date: Aug 26 '19
Time: 10:01pm
LateGreat
Date: Aug 25 '19
Time: 11:18am
Comments: 31
Date: Aug 10 '19
Time: 3:02pm
Attached by: markmitch
Comments: 31
Date: Dec 07 '18
Time: 7:35pm
Comments: 31
Date: Dec 03 '18
Time: 1:39am
