Lowering Springs for us Late-Model guys
Postby FrankenRodz [OP] » April 27th 2010, 11:08am
There seems to be a lot of difficulty lowering the newer model Astro/Safaris, but when I did a search Chassis Tech came right up. 3-4" drop leaf springs for not a lot of money. Anybody use these? Seems like an easy solution to get our rides out of the sky.
springshttp://www.cheaptruckparts.com/p ... aae6b04352
Design - Consultation - Project Management
For Whatever Moves You
FrankenRodz
Years of Membership: FrankenRodz has been a member for 10 full yearsFrankenRodz has been a member for 10 full yearsFrankenRodz has been a member for 10 full yearsFrankenRodz has been a member for 10 full yearsFrankenRodz has been a member for 10 full yearsFrankenRodz has been a member for 10 full yearsFrankenRodz has been a member for 10 full yearsFrankenRodz has been a member for 10 full yearsFrankenRodz has been a member for 10 full yearsFrankenRodz has been a member for 10 full years
Topics: 9
  • Lowering Keys torsion bar
    by dutch astro driver » December 16th 2020, 1:57pm in Lowered Suspension
    December 17th 2020, 10:07pm
    52
    February 28th 2021, 7:55am
Re: Lowering Springs for us Late-Model guys
Postby astroturf » April 27th 2010, 3:24pm
FrankenRodz wrote:There seems to be a lot of difficulty lowering the newer model Astro/Safaris, but when I did a search Chassis Tech came right up. 3-4" drop leaf springs for not a lot of money. Anybody use these? Seems like an easy solution to get our rides out of the sky.
Man, That seems like a pretty good deal. But, I think at 3 to 4 inches you would begin to ride on the bump stops. Welcome to the Board. And post some pics of your ride. We like pix. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby FrankenRodz [OP] » April 28th 2010, 10:23am
Thanks for the welcome. Just found them for even less $.
I'll give them a try, and post before/after pics, and give a ride analysis.
FrankenRodz
Topics: 9
Postby rev_les » May 10th 2010, 4:56pm
FrankenRodz wrote:Thanks for the welcome. Just found them for even less $.
If you don't mind me asking, where'd you find them for even less $$ ? I lowered my front and now I need to lower the back to even it back out, otherwise I gotta put fat tires on the back and skinnys on the front, and since I don't have the v-8 conversion, it seems a bit silly :lol:
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby FrankenRodz [OP] » May 16th 2010, 8:42pm
http://www.airbagit.com/product-p/lea-as8400-3.htm
AirBaggit.com
Sorry for the delayed response. The deal fell through on the van, so I just bought a '97 today.
FrankenRodz
Topics: 9
Postby astroturf » May 16th 2010, 9:30pm
FrankenRodz wrote:http://www.airbagit.com/product-p/lea-as8400-3.htm
AirBaggit.com
Congrats on your new van. Jim
astroturf
Topics: 112
Postby scr8pnyota » July 9th 2010, 6:47pm
yea im on the hunt for a drop kit for a 2005 rwd. found a belltech kit though work but not 100% will work on a 6 lug van??? the flip kit should be the same as the 02 and older? thinkin about just bagging the front and static drop the rear.
scr8pnyota
Years of Membership: scr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full yearsscr8pnyota has been a member for 12 full years
Images: 3
Postby Surfari99 » July 16th 2010, 8:49am
:naughty:
I do not recomend installing the dropped leaf springs , I bought the cheap kit from Ground force came with 2 ' dropped coils , 3" dropped steel rear leafs , the load capacity sucks on the lowered leafs and unlike the flip kit that changes the position of your stock axle leafs with a load or a family trip you will be banging around in the rear with or without the bump stops .
I regret the choice so I bought 2" belltech Spindles I used the 2" dropped Coils as well in front w/o them it was not low enough for me , and I am about to remove the dropped leafs and install a DJM flip kit it has 3 hieght positions and put my stock leafs back on ,, By the way if you are just changing Spindles you do not need to remove your front coils I was amazed at how fast it was only need to disconect calipers upper lower joints and tie rod put new spindle on the same way ..
ALmost Forgot the Rotors but if you are carefull the bearing will stay in there ............
DO NOT Buy THE CHEAP KIT !!!!!!!!!!!!! :naughty:
Surfari99
Years of Membership: Surfari99 has been a member for 11 full yearsSurfari99 has been a member for 11 full yearsSurfari99 has been a member for 11 full yearsSurfari99 has been a member for 11 full yearsSurfari99 has been a member for 11 full yearsSurfari99 has been a member for 11 full yearsSurfari99 has been a member for 11 full yearsSurfari99 has been a member for 11 full yearsSurfari99 has been a member for 11 full yearsSurfari99 has been a member for 11 full yearsSurfari99 has been a member for 11 full years
Topics: 20
Images: 24
Alias (AKA): N/A
Extra Info: SLE EXT 4.3L RWD
Return to Lowered Suspension
It is currently February 28th 2021, 7:55am
Lowered Suspension Forum
Lowered SuspensionLowering Suspension, Slamming, Flip-kits, Spindles, Shackles, Hangers, Lowering Coils, Air Bags, Hydraulics.
To create a new topic in Lowered Suspension, click this button:
TBLBill
Date: Aug 26 '19
Time: 10:01pm
LateGreat
Date: Aug 25 '19
Time: 11:18am
Comments: 31
Date: Aug 10 '19
Time: 3:02pm
Attached by: markmitch
Comments: 31
Date: Dec 07 '18
Time: 7:35pm
Comments: 31
Date: Dec 03 '18
Time: 1:39am
cron
