allingment after torsion adjusment?
Postby cowboydan [OP] » July 19th 2010, 2:12pm
if i adjusted my torsion bars, that moves my camber? when i had my wheel allignment done, they only adjusted the steering tierods. as far as i know there is no camber adjustment. the camber seems like it would be set by the steering knuckles (factroy). the control arms only pivot up and down. the balljoints allow turning movement. i'm sure that the shop would tell me that my camber is off but even they would only be able to make adjustments using the screws that i would have already messed with. i just had tires put on my van and i'm convinced that no matter what, i will cook the inside of the tires. have i missed something? i think that to properly lower atleast my van, i would need a camber kit consisting of shims possibly under the wheel bearing assembly or new upper control arm measured for specific drop incriments
2006 sebring 2.7 touring: DD
cowboydan
Firing on 8 Cylinders (L2)
Topics: 67
Alias (AKA): cbd
Extra Info: 4.3w CL AWD
  • Lowering Keys torsion bar
    by dutch astro driver » December 16th 2020, 1:57pm in Lowered Suspension
    December 17th 2020, 10:07pm
    22
    April 14th 2021, 9:12pm
Re: allingment after torsion adjusment?
Postby Dirk » July 19th 2010, 2:18pm
The upper control arm has shims behind the mounting point.
Adding or removing shims is the only way that I know of to properly adjust camber on Astro Vans.
1985 Astro conversion, engine type N 4.3 4BBL
If you can't fix it with a hammer you've got an electrical problem!
Parts are cheap breakdowns expensive.
Don't worry about miles per gallon, worry about smiles per gallon!
Dirk
Firing on 8 Cylinders (L1)
Years of Membership: Dirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full years
Images: 11
Extra Info: 4.3L 4BBL
Postby astroturf » July 19th 2010, 2:22pm
If the shop you took it to after your drop via torsion bar adjustment only adjusted the Toe. I would call that a Toe & Go Shop. It could also be that your caster was within specs. Do you have a print out of your before and after readings? If not and it is in fact out of spec, yes you will see an increase in tire wear.
Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby chevy57bert » July 19th 2010, 7:07pm
astroturf wrote: I would call that a Toe & Go Shop.
:rofl: :rofl: :rofl: Yeb Turf..
When I go to the Tire shop. The big chef helps me, because I won`t let 17/18 Year old children work on me Van.....
But now we have our own alignment equipment for 18 wheelers. all fancy laser stuff..
( I did order some tools to set-up some small 18 wheelers Like ASTRO Vans) :rofl: :rofl:
like Jim said, watch for tire wear.
chevy57bert
Section Moderator
Section Moderator
Firing on 8 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Postby astroturf » July 19th 2010, 8:08pm
Small 18 Wheel Astros...
Good One Bert
astroturf
Topics: 112
Postby chevy57bert » July 19th 2010, 9:14pm
astroturf wrote:Small 18 Wheel Astros...
Good One Bert
You don`t have to buy that. ( I told me Chef `We need that for smaller trucks ` :rolling: :rolling: )
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby cowboydan [OP] » July 19th 2010, 9:22pm
i havn't adjusted the screws on the torsion bars. and i'm not going to. atleast not till i figure out how to set my camber.
cowboydan
Topics: 67
Alias (AKA): cbd
Postby chevy57bert » July 19th 2010, 9:35pm
cowboydan wrote:i havn't adjusted the screws on the torsion bars. and i'm not going to. atleast not till i figure out how to set my camber.
Does your Van stays strait?
Does it leans over to one side?
Do you have Front tire wear?
One of does things require alignment..
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby cowboydan [OP] » July 20th 2010, 12:31am
yep
nope
nope
but i will if i touch those screws. i just paid over $600 for new tires. i'd like to keep em new, atleast for the moment
cowboydan
Topics: 67
Alias (AKA): cbd
Postby chevy57bert » July 20th 2010, 6:57pm
Found this for you (and others )
Wheel alignment Astro Safari 85 - 96 in PDF.
1985 1996 alignment specs.pdf
(33.78 KiB) Downloaded 59 times
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby astroturf » July 20th 2010, 7:02pm
Good Find Bert
Saved
Jim
astroturf
Topics: 112
Postby cowboydan [OP] » July 21st 2010, 1:33am
thanks
cowboydan
Topics: 67
Alias (AKA): cbd
Return to Lowered Suspension
It is currently April 14th 2021, 9:12pm
Lowered Suspension Forum
Lowered SuspensionLowering Suspension, Slamming, Flip-kits, Spindles, Shackles, Hangers, Lowering Coils, Air Bags, Hydraulics.
To create a new topic in Lowered Suspension, click this button:
Date: Mar 22 '21
Time: 1:57pm
TBLBill
Date: Aug 26 '19
Time: 10:01pm
LateGreat
Date: Aug 25 '19
Time: 11:18am
Comments: 31
Date: Aug 10 '19
Time: 3:02pm
Attached by: markmitch
Comments: 31
Date: Dec 07 '18
Time: 7:35pm
