New to Site
Please do not post support requests in the new members lounge! This forum is for new member introductions and assistance only. Please post other topics in their appropriate areas so they stay categorized.
New to Site
Postby twincitieschef [OP] » September 5th 2016, 5:21pm
Hi guys,
My name is Luke, I am new to the site. I am currently living in Stillwater MN and would love to meet some other Astro fans in the Twin Cities! I recently just picked up an 02 Astro LT AWD with 180k on it. I found it with high mileage but the damn thing has only been through 2 previous owners and garaged it's whole life. Planning on turning this van into a camping rig!!
The good;
Very little body rust
Limited frame rust
Newer exhaust
Tight front end ie; Links, Sways, bearings
Newer Brakes
good glass
solid drive shaft
suspension is good
new battery
Clean Fluids
The bad;
intermittent squeaking noise coming from either Tension pulley or Fan Clutch
Needs new AWD Transfer Case Motor
some leakage of oil/fluids from underneath might need a good pressure wash to diagnose leak
Drivers side door needs to be re set on pins, does not seal all the way shut.
Drivers side door interior is a little rough/cracked.
twincitieschef
Years of Membership: twincitieschef has been a member for 4 full yearstwincitieschef has been a member for 4 full yearstwincitieschef has been a member for 4 full yearstwincitieschef has been a member for 4 full years
Images: 4
Van Model Year: 2002
Extra Info: LT 180k 4.3L V6 AWD
  • New to site
    by Kman947 » August 3rd 2020, 5:12pm in Member Introductions
    August 12th 2020, 4:22pm
  • What an awesome site!
    by Renaissance Uph » July 24th 2020, 5:56pm in Member Introductions
    Last post by Ironsides View the latest post
    July 25th 2020, 12:49am
    89
    October 27th 2020, 11:07am
Re: New to Site
Postby LexTempus » September 6th 2016, 2:16am
Welcome to the site. Good luck with your conversion and as I always say, "never ever use the handle mounted on the dash that's on the passenger side."
Everything breaks.
LexTempus
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: LexTempus has been a member for 4 full yearsLexTempus has been a member for 4 full yearsLexTempus has been a member for 4 full yearsLexTempus has been a member for 4 full years
Re: New to Site
Postby markmitch » September 6th 2016, 3:12am
welcome to the forum and good luck on your project and oh by the way we love pictures here. take your belt off and check the pulleys the squeak could be a pulley bearing or alternator or any one of the pulleys.The door may be that your door striker needs to be adjusted.
Firing on 5 Cylinders (L6)
Topics: 608
Images: 20
Extra Info: RS V8
Re: New to Site
Postby Leeann_93 » September 6th 2016, 3:31am
Welcome!
Did the guys mention photos? We love photos here.
It is possible it's the belt or tensioner, but as Mark said, it's more likely the idler pulley or alternator bearing. If you loosen the belt and spin each by hand, you'll hear/feel it.
Re: New to Site
Postby Astrofarian » September 6th 2016, 5:28am
Hi and welcome. I replied to your other thread about the AWD issue. Hope you get the van the way you want it without any headaches!
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Return to Member Introductions
It is currently October 27th 2020, 11:07am
Member Introductions Forum
Member IntroductionsHello and welcome to the best and original home for Astro & Safari owners. Please introduce yourself to the community and make yourself at home. Tell us about yourself and post your introductions and welcome messages here.
To create a new topic in Member Introductions, click this button:
Date: Oct 23 '20
Time: 5:24pm
Date: Oct 23 '20
Time: 5:21pm
foxfire
Date: Oct 22 '20
Time: 4:35pm
foxfire
Date: Oct 22 '20
Time: 3:03pm
foxfire
Date: Oct 22 '20
Time: 1:26pm
