Chevy Astro door latch won’t stay closed
Please do not post support requests in the new members lounge! This forum is for new member introductions and assistance only. Please post other topics in their appropriate areas so they stay categorized.
Postby Ihaveclout [OP] » July 20th 2020, 2:19pm
I have to pull in the inside handle to be able to move the latch down so it can close all the way but it won’t stay closed meaning I have to drive while holding the driver side door open cause it will open while I’m driving. Does anyone one how to fix this I’m thinking it can be a broken latch but it’s hard to see in there???
Ihaveclout
Van Model Year: 2002
Extra Info: V6
Re: Chevy Astro door latch won’t stay closed
Postby augidog » July 21st 2020, 10:24pm
outside handle (half) broken, and the rod's wonky & not traveling right?
my new handle's hinge is drilled off center, bad QC, and it barely pulls enough to release the latch. it slightly snags before it lets go. after that, it rotates and latches fine, so I figure that edge will wear down soon enough.
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby sixsix » July 22nd 2020, 2:54am
augidog wrote:outside handle (half) broken, and the rod's wonky & not traveling right?
What ...?
To the OP - it sounds like you need to take the inner or lower panel off the hatch and check the latch mech on each side.
Clean and Lube - R and R.
Well, after all... what would Banacek say ?... “It is only a matter of time before armed citizens, waiting or not for the police, take things into their own hands, fire on the rioters for personal and property prot. & end up hunted like dogs.”
Firing on 2 Cylinders (L5)
Topics: 37
Images: 1254
Postby augidog » July 22nd 2020, 3:27am
What ...?
you've misread the OP, that's what.
Touche Turtle.jpg (13.44 KiB) Viewed 190 times
augidog
Topics: 16
Alias (AKA): Augie
Postby Rod's Trucks » July 22nd 2020, 3:43am
Sixsix,
I have to agree with Augidog's comment.
I read it that the OP was concerned with a driver door ( something like "..having to hold it shut while driving..." does not sound like a rear hatch to me. :2:
Rod J
Rod's Trucks
Topics: 19
Images: 44
Alias (AKA): Rod and/or WE7X
Postby augidog » July 22nd 2020, 4:05am
and before we have any MORE misunderstandings...Rod, I wasn't calling YOU "wonky" :rofl:
(I mean, I dunno, you might be, but I don't judge)
augidog
Topics: 16
Alias (AKA): Augie
Postby sixsix » July 22nd 2020, 3:27pm
First off, I forgot ... Welcome Ihaveclout from all of us here in Ky.
We have Clout also. I think it's in Campbell Co - across from New Richmond. LOL
What ...?
Yes, Members, I misread the post. Latch, Hatch... oh well, something's amiss - and there is a problem w/ the driver's door LATCH mechanism.
They are not an easy thing to remove, change or clean.
When I rebuilt our Driver's Door - the LATCH was the last thing I removed.
Could it simply be a matter of pulling the handle and 'prying' out on the "LATCH Catch" ( not sure of the Tech. Term ).
If need be I can post a pic...
I am also not sure if these LATCHES are still available other than a JY.
Other than the Gen I Dash Climate Control Module - The Door LATCH has to be the most complicated Mechanical device on these Vans. Ours was filthy, sluggish, embarrassed and most of all, confusing w/o seeing what/how the rods and components interact.
Here's to Hoping Everyone Feels Better - :cheers:
And about this...
augidog wrote:and before we have any MORE misunderstandings...Rod, I wasn't calling YOU "wonky" :rofl:
:eek: :shock: :eek:
Really?... augi, that's a riot - great thread!
Should this be slid over to The Exterior sub-forum ? No biggee tho' for the New Member.
Topics: 37
Images: 1254
Postby augidog » July 22nd 2020, 4:16pm
full disclosure...sixsix, I had misread YOUR post, and for a moment I took issue with it. I had to re-read it to realize you'd misread the OP, and I so re-wrote my response in a big hurry. I even threw in a turtle for comedy relief. I don't know what's your thing with turtles, but I don't judge.
the OP wasn't exactly clear and concise (you know how I feel about that) and one sentence made it even more difficult to get a grasp. I had to do a double take before being sure I wanted to guess. a bad outside handle (or other wonky linkage) could result in the symptoms as described, maybe nothing wrong with the latch itself, but I used a question mark just in case. as the owner of a '95 I use a LOT of question marks.
:cheers:
augidog
Topics: 16
Alias (AKA): Augie
Postby Rod's Trucks » July 22nd 2020, 4:25pm
I've probably been 'wonky' at one time or maybe even many, but it does not bother me.
I've been known to misinterpret the writings of others many times, and I am VERY sure I will do it again, so 'BTDT' applies.
No harm done.
Rod J :wave:
Rod's Trucks
Topics: 19
Images: 44
Postby bradaskins » July 22nd 2020, 4:39pm
I'm so confused by this whole thread.
bradaskins
Years of Membership: bradaskins has been a member for 1 full year
Topics: 41
Alias (AKA): Breaking Brad
Postby augidog » July 22nd 2020, 4:50pm
bradaskins wrote:I'm so confused by this whole thread.
well then, it looks like our plan worked :rolling:
augidog
Topics: 16
Alias (AKA): Augie
Postby sixsix » July 22nd 2020, 9:11pm
Turtles ?
Topics: 37
Images: 1254
Postby augidog » July 22nd 2020, 9:14pm
augidog
Topics: 16
Alias (AKA): Augie
Return to Member Introductions
It is currently September 21st 2020, 9:11pm
Member Introductions Forum
Member IntroductionsHello and welcome to the best and original home for Astro & Safari owners. Please introduce yourself to the community and make yourself at home. Tell us about yourself and post your introductions and welcome messages here.
To create a new topic in Member Introductions, click this button:
Time: 8:14pm
Comments: 841
Time: 12:01am
Date: Sep 12 '20
Time: 3:01am
Date: Sep 11 '20
Time: 9:16pm
Date: Sep 09 '20
Time: 10:37pm
Users browsing this forum: Yandex [Bot] and 8 guests
