Finally Joined
Please do not post support requests in the new members lounge! This forum is for new member introductions and assistance only. Please post other topics in their appropriate areas so they stay categorized.
Finally Joined
Postby TPP [OP] » August 4th 2020, 10:27pm
Been lurking on here since the lock down started, wanted to get an Astro or Safari since the beginning of the year, finally found the "right one" a month ago after browsing rust buckets on craigslist for months.
So far I've ripped off the cladding and running boards, pulled the back bench and carpet due to dutch door leak. On the fence about making it into a camper. I have access to a CNC machine and have a background in engineering, carpentry, metal working, and mechanics.
Located in York Co. PA.
TPP
Extra Info: SLT AWD
  • lurks-a-lot finally joined
    by foxfire » October 22nd 2020, 1:44pm in Member Introductions
    Last post by foxfire View the latest post
    November 14th 2020, 10:45pm
    November 24th 2020, 9:59am
Re: Finally Joined
Postby tungtide » August 5th 2020, 1:09am
Welcome aboard. Lots of good information here. Let the fun begin.
Ken
tungtide
Topics: 23
Images: 12
Alias (AKA): tungtide
Van Model Year: 2002
Re: Finally Joined
Postby Leeann_93 » August 6th 2020, 3:56am
Welcome!
I’m not too far down the road in Annapolis.
Re: Finally Joined
Postby markmitch » August 6th 2020, 4:19am
welcome to the best place for Astro/Safari vans, Mark
Firing on 6 Cylinders (L6)
Topics: 614
Images: 20
Extra Info: RS V8
Re: Finally Joined
Postby Rod's Trucks » August 6th 2020, 5:28am
Welcome!
With your background, you can probably find all kinds of things to work on/modify/delete/change/re-modify/redesign, etc: and never get to use your van.
Wish you were located out west :rockon:
Rod Johnson
Rod's Trucks
Topics: 24
Images: 54
Alias (AKA): Rod and/or WE7X
Re: Finally Joined
Postby Astrofarian » August 6th 2020, 12:07pm
Hi, and welcome from rural Manitoba, Canada. As an Engineer, you may want to explore a few of Wimpy's threads on the camper idea; specifically "Wimpfalia" as he was working on a kind of modular approach to building these things out. And DEFINITELY, you're on the right track with deleting the cladding...nothing but a rust magnet.
Best of luck to you in your build!
-M!ke-
Edited 1X - Spelling
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Re: Finally Joined
Postby Ironsides » August 6th 2020, 2:08pm
Welcome!
Cladding delete, good move to start imo, wish I did it earlier.
I also started with a dutch door leak, years later I'm finding electrical issues related to moisture corrosion, but that's Florida where any moisture inside becomes steam and finds it's way into everything.
Definitely share what ideas you machine for your van.
Good luck with your camper upgrade.
Ironsides
Years of Membership: Ironsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full years
Topics: 5
Van Model Year: 2001
Extra Info: RWD Custom HD
Re: Finally Joined
Postby augidog » August 6th 2020, 4:06pm
welcome 8-)
in case you're interested, this is a scanned original GM Dealer packet for your '04
https://www.gmheritagecenter.com/docs/g ... ro-Van.pdf
also, I had great luck working with Steele Rubber Products, and they've developed an excellent set of reproduction seals for the Dutch Doors.
https://www.astrosafari.com/viewtopic.php?f=11&t=141714
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Return to Member Introductions
It is currently November 24th 2020, 9:59am
Member Introductions Forum
Member IntroductionsHello and welcome to the best and original home for Astro & Safari owners. Please introduce yourself to the community and make yourself at home. Tell us about yourself and post your introductions and welcome messages here.
To create a new topic in Member Introductions, click this button:
Comments: 27
Time: 7:50pm
ptysiek
Comments: 27
Date: Nov 22 '20
Time: 10:41pm
ptysiek
Comments: 27
Date: Nov 22 '20
Time: 10:39pm
Comments: 27
Date: Nov 22 '20
Time: 7:04pm
ptysiek
Comments: 27
Date: Nov 22 '20
Time: 4:09pm
