I found this website because I am researching what kind of towing package I want to have put on Astro; I named it Astro after the great dane from the Jetsons (cartoon)...weird coincidence or fate?
I'm also researching travel trailers and how to prep Astro for driving over the cascade mountains as safely as possible. I've already come across some helpful tips about having coolant added, trailer brakes, etc.
Also, I have been having some odd problems with the drivers' side door handle and/or lock, occasionally the lock gets stuck; when the door is open and it is stuck the door itself cannot fully close and when the door is closed and it is stuck the door cannot be opened from the outside. The only way to get it unstuck is to use a screwdriver so I now keep one in the glove compartment. Anyone have this problem before? I would also like to remove the ugly chipped window deflectors, does denatured alcohol really work?
