Bad Bushings ? Common Lifted Astro Noises ?
Postby ormoto [OP] » November 28th 2016, 2:16am
Got a 01 Astro lifted 3in on 30in tires and as time goes on it seems to be making more and
more creeking noises and rubbing noises.
Its got 160k on it
Lifted Since 140 otherwise totally stock.
What kind of bushing replacement have you guys got into ?
Already done sway bar and endlinks but it seems there is lots more under there
Control Arm / Motor / Transmission mounts ? Whats common
Explore !
ormoto
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: ormoto has been a member for 4 full yearsormoto has been a member for 4 full yearsormoto has been a member for 4 full yearsormoto has been a member for 4 full years
Topics: 7
Images: 25
Van Model Year: 2001
Extra Info: 4.3L AWD
Re: Bad Bushings ? Common Lifted Astro Noises ?
Postby chevymaher » November 28th 2016, 3:29am
My transmission mount made a horrible racket. Thumping and carrying on when it was bad.
Postby Lumpy » November 28th 2016, 6:48pm
What kind of lift?
Did it squeek before the lift?
See what I did there.. 8-)
Postby ormoto [OP] » November 28th 2016, 7:11pm
Ive got the Journey Off Road's 2"-5" Super Lift Kit for a 1996-2005 Kit on it.
The kits been on for 30k and the noises are new, it mainly does it when going in reverse under full or near full turn then going forward, or when offroading it does it often when flexing of the frame occurs over small ditches and changes in flex. Here are some photos of some bushings that dont look amazing
627786277062762
Explore !
ormoto
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 7
Images: 25
Postby 97cargocrawler » November 28th 2016, 8:04pm
See I just look at that and think, "hmmmm...the bushings look old so it's time to replace all of them." Regardless of noises.
Last edited by 97cargocrawler on November 29th 2016, 3:49am, edited 1 time in total.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby Mmusicman » November 29th 2016, 2:12am
No squeaks on mine.
Body lifts leave the front suspension stock.
But worn bushing certainly can squeak... lifted or not.
Firing on 5 Cylinders (L5)
Topics: 72
Images: 49
Postby MI_Ghost » November 29th 2016, 7:59pm
ormoto wrote:Control Arm / Motor / Transmission mounts ? Whats common
At 140K you can likely expect Control Arm / Motor / Transmission / Body / Leaf Spring / Differential mounts/bushings.
There are poly replacements for nearly all of them. The differential bushings may be the exception.
Old rubber dries out and turns hard losing the ability to flex. When you added the lift. You changed the working range to further aggravate the deterioration. That is why it showed up so soon after adding the lift.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
MI_Ghost
Years of Membership: MI_Ghost has been a member for 4 full yearsMI_Ghost has been a member for 4 full yearsMI_Ghost has been a member for 4 full yearsMI_Ghost has been a member for 4 full years
Images: 107
Alias (AKA): Ghost
Extra Info: Big White RWD Box
Postby Mmusicman » November 29th 2016, 8:04pm
You could always temporarily try a little oil or grease on those bushings...
Topics: 72
Images: 49
Postby ormoto [OP] » November 29th 2016, 9:55pm
MI_Ghost wrote:
ormoto wrote:Control Arm / Motor / <a class="vglnk" title="Link added by VigLink" target="_blank" href="http://rover.ebay.com/rover/13/0/19/DealFrame/DealFrame.cmp?bm=259&BEFID=96477&acode=304&code=304&aon=&crawler_id=518276&dealId=SHOlEo9cpZP_i4VsZS6BDg%3D%3D&searchID=&url=http%3A%2F%2Fcarcomputerexchange.com%2Fchrysler%2Ftown-and-country%2F2002-chrysler-town-country-tcm-transmission-control-module%2Fprod_268.html%3Futm_source%3Debaycommercenetwork%26utm_medium%3Dcpc%26utm_term%3D%7Bkeyword%7D%26utm_campaign%3DPPCGuysFeeds%26utm_content%3D2002%2Bchrysler%2Btown%2Bcountry%2Btcm%2Btransmission%2Bcontrol%2Bmodule&DealName=2002%20Chrysler%20Town%20%26%20Country%20TCM%20Transmission%20Control%20Module&MerchantID=518276&HasLink=yes&category=0&AR=-1&NG=1&GR=1&ND=1&PN=1&RR=-1&ST=&MN=msnFeed&FPT=SDCF&NDS=1&NMS=1&NDP=1&MRS=&PD=0&brnId=2455&lnkId=8070676&Issdt=161127052733&IsFtr=0&IsSmart=0&dlprc=199.0&SKU=200L7" rel="nofollow"><span>Transmission</span></a> mounts ? Whats common
At 140K you can likely expect Control Arm / Motor / <a class="vglnk" title="Link added by VigLink" target="_blank" href="http://rover.ebay.com/rover/13/0/19/DealFrame/DealFrame.cmp?bm=259&BEFID=96477&acode=304&code=304&aon=&crawler_id=518276&dealId=SHOlEo9cpZP_i4VsZS6BDg%3D%3D&searchID=&url=http%3A%2F%2Fcarcomputerexchange.com%2Fchrysler%2Ftown-and-country%2F2002-chrysler-town-country-tcm-transmission-control-module%2Fprod_268.html%3Futm_source%3Debaycommercenetwork%26utm_medium%3Dcpc%26utm_term%3D%7Bkeyword%7D%26utm_campaign%3DPPCGuysFeeds%26utm_content%3D2002%2Bchrysler%2Btown%2Bcountry%2Btcm%2Btransmission%2Bcontrol%2Bmodule&DealName=2002%20Chrysler%20Town%20%26%20Country%20TCM%20Transmission%20Control%20Module&MerchantID=518276&HasLink=yes&category=0&AR=-1&NG=1&GR=1&ND=1&PN=1&RR=-1&ST=&MN=msnFeed&FPT=SDCF&NDS=1&NMS=1&NDP=1&MRS=&PD=0&brnId=2455&lnkId=8070676&Issdt=161127052733&IsFtr=0&IsSmart=0&dlprc=199.0&SKU=200L7" rel="nofollow"><span>Transmission</span></a> / Body / Leaf Spring / Differential mounts/bushings.
Dang thats alot alot of labor lol but i think ill have to tackle it sooner or later so might as well get started.
Any recommendations for quality bushing kits ?
http://www.jegs.com/i/Energy+Suspension ... fgod8qYD4g
Any idea the rough hours of labor were talking here
Explore !
ormoto
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 7
Images: 25
Postby Lumpy » November 30th 2016, 4:58am
ormoto wrote:Ive got the Journey Off Road's 2"-5" Super Lift Kit for a 1996-2005 Kit on it.
Oh that.
Add an XT-45 DML to the bottom of the SLK and you will definitely see improvement. Don't use an XLT-45, just an XT-45. And don't be tempted to use the XD-4 or the XD-5.
Postby ormoto [OP] » November 30th 2016, 6:29am
What's a slk and xt45
Explore !
ormoto
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 7
Images: 25
Postby dramey » November 30th 2016, 7:12am
Oh that.
Try again in English. What is an XT-45, DML, SKL, XLT-45, XD-4, and XD-5? Complete words would be a big help for people to understand what it is you are trying to tell them.
dramey
Firing on 7 Cylinders (L1)
Topics: 12
Extra Info: AWD Cargo Van
Postby MI_Ghost » November 30th 2016, 7:33am
ormoto wrote:What's a slk and xt45
Thats lumpy code for sticking the thingamabob in the doohickey to make a whatchamacallit!
Or was that a whoziewhatzit? :confused: :shrug: :shrug:
He is still trying to figure it out also! :D
~Ghost
MI_Ghost
Images: 107
Alias (AKA): Ghost
Postby MI_Ghost » November 30th 2016, 7:49am
ormoto wrote:Any recommendations for quality bushing kits ?
Energy suspension or prothane make the poly kits in red or black. My understand is the black are supposed to have graphite in them to help reduce the squeaking common with poly bushings.
If you think your going to do them all at one time. Plan for a good week of work. It is usually better to tackle them as you are working on the area the are in. Doing a body lift - Do the body mounts. Replacing the ball joints - Knock out the control arm bushings.
Polyurethane is more stable a a bit stiffer than regular rubber so the ride will feel a little firmer and you may notice more vibration and shock from the road.
~Ghost
MI_Ghost
Images: 107
Alias (AKA): Ghost
Postby chevymaher » November 30th 2016, 1:51pm
I used Energy Suspention on my chev for the front end and the rear trailing arms. They come with a tub of real thick lube you apply to the bushings before you put them on.
Being as my chev is a garage ornament and never moves much. I can't really comment on long term. But my brother used the same thing on his charger. He drove it all summer. He is a little ahead of me lucky SOB. Anyway it didn't squeak if it is applied right.
Mine has went only a mile or so over the years with no motor in it. But so far so good. Yes I am a Big Kid I took a few go Kart rides when I could getting it on and off of the trailers. Oh boy put the truck and trailer at the bottom of the hill I will roll down to it. Easier and more fun.
Postby Coaster » November 30th 2016, 2:19pm
lumpy your response shows you are intolerant of lack of proper description. please call bruce jenner
I LIVE IN NORTH DAKOTA
Coaster
Topics: 113
Extra Info: 4.3 cargo 2wd
Postby AstroWill » November 30th 2016, 6:10pm
MI_Ghost wrote:Energy suspension or prothane make the poly kits in red or black. My understand is the black are supposed to have graphite in them to help reduce the squeaking common with poly bushings.
According to their FAQ, only "select" black bushings have graphite in them.
http://www.energysuspensionparts.com/faq.asp
In 2016 ~66mil voted for Clinton, ~63mil voted for Trump and ~100mil(eligible) didn't vote Make a difference - register+vote!
Topics: 106
Images: 438
Postby Lumpy » November 30th 2016, 8:03pm
They are totally non-descriptive trade names that don't mean anything to you. So my comments aren't clear or helpful to you.
See what I did there?
Postby Coaster » December 1st 2016, 3:02am
maybe its an updog problem?
Coaster
Topics: 113
Postby dramey » December 1st 2016, 6:01am
Lose credibility?
dramey
Topics: 12
Return to Lifted Suspension
It is currently October 1st 2020, 4:53am
Lifted Suspension Forum
Jakob1994
Date: Sep 17 '20
Time: 5:03pm
Attached by: ri$e*above
ri$e*above
Comments: 9
Date: Jul 11 '20
Time: 7:10pm
ri$e*above
Date: Jul 10 '20
Time: 7:47pm
ri$e*above
Comments: 9
Date: Jul 10 '20
Time: 2:37am
Attached by: Coaster
Coaster
Date: Jun 28 '20
Time: 5:56pm
Users browsing this forum: Google [Bot] and 4 guests
