Solid Axel Swap
Solid Axel Swap
Postby orion33 [OP] » June 15th 2011, 9:04pm
How hard is it to put a solid axel in a 90 AWD astro?i would like to change the transfer case as well so i have hi and low and 2WD.I AM A WELL ACCOMPLISHED MECH,so im sure turning the wrenches wont be a prob.would just like some insight from someone who has done one! :think:
Astros are out of this World!Beam me up Scotty!
orion33
Years of Membership: orion33 has been a member for 9 full yearsorion33 has been a member for 9 full yearsorion33 has been a member for 9 full yearsorion33 has been a member for 9 full yearsorion33 has been a member for 9 full yearsorion33 has been a member for 9 full yearsorion33 has been a member for 9 full yearsorion33 has been a member for 9 full yearsorion33 has been a member for 9 full years
Alias (AKA): Torry
Extra Info: CL 4.3 AWD Shrty
Re: Solid Axel Swap
Postby Dirk » June 15th 2011, 9:08pm
Take a look in at projects and build topics there are a few guys that have mounted entire 4x4 chassis under an Astro!
One of these topics should provide you with some information or at least a good idea of what has to be done.
https://www.astrosafari.com/viewtopic.php?f=127&t=9217
https://www.astrosafari.com/viewtopic.php?f=127&t=4103
1985 Astro conversion, engine type N 4.3 4BBL
If you can't fix it with a hammer you've got an electrical problem!
Parts are cheap breakdowns expensive.
Don't worry about miles per gallon, worry about smiles per gallon!
Dirk
Firing on 8 Cylinders (L1)
Years of Membership: Dirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full years
Images: 11
Extra Info: 4.3L 4BBL
Return to Lifted Suspension
It is currently November 27th 2020, 8:47am
Lifted Suspension Forum
pmou
Comments: 59
Date: Nov 24 '20
Time: 11:40pm
pmou
Comments: 59
Date: Nov 24 '20
Time: 10:30pm
wilsc449
Comments: 20
Date: Nov 18 '20
Time: 7:08pm
pmou
Comments: 59
Date: Nov 14 '20
Time: 7:54pm
pmou
Comments: 59
Date: Nov 13 '20
Time: 9:53pm
