2003-2005 rear sway bar help (brake line problem)
Postby vanderbeek [OP] » July 14th 2017, 5:11pm
Hello everyone!
I purchased the Hellwig rear sway bar for my 2004 lifted Astro, and in trying to follow the instructions (which are VERY poorly documented) it shows that the Ubolts can go under the brake lines to not interfere or rub on them. However, on my 2004 there doesn't seem to be a way to do that, it looks like i can only mount the U-bolts so they are right against the brake lines. My thought is that the switch to rear disc brakes in 2003-2005 could mean the brake lines are mounted differently from previous models. Does anyone else have a 2003-2005 model that they've solved this problem for? Here is a pic below of how i tried to install it (but took off immediately).
PS, absolutely LOVING my lifted AWD Astro. Took it on my first camping trip with the wife and at first she was skeptical of the van, now she is absolutely in love with what it can do!
thanks!
Mac
vanderbeek
Years of Membership: vanderbeek has been a member for 3 full yearsvanderbeek has been a member for 3 full yearsvanderbeek has been a member for 3 full years
Alias (AKA): vanderbeek
Extra Info: LS AWD Passenger
Re: 2003-2005 rear sway bar help (brake line problem)
Postby TurnNburn » July 14th 2017, 5:30pm
I did not like the idea of the brake line being stuck in between the axle and the u-bolt, so I bent my brake lines (gently) away from the axle and put it on the outside of the u-bolt. Then used some appropriately sized rubber hose, cut it down the middle and zip tied it onto the brake line to keep the rubbing to a minimum.
Also, kind of tricky to see in the picture due to the angle, but it looks like your mounts are really close to the center of the axle. I think you should move that mount further out towards the end of the sway bar to improve the leverage of the bar.
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby vanderbeek [OP] » July 14th 2017, 7:48pm
Interesting, do you have any pictures you could snap? Its hard to see in my picture (sorry) but the brake line on my axle is very close to the axle tube. Maybe it has to do with the switch to disc brakes for 03-05 axles.
I'll take another look at my axle to see if I could gently bend the brake line, and I'll see if i can move the bar mount closer to the wheel as per your advice.
thanks!
vanderbeek
Postby TurnNburn » July 14th 2017, 8:00pm
Here is what I was talking about routing behind the u bolt.
Of course this from a terrible point of view so that you cant see the u bolt on this side, but you can see how far over my mount is
TurnNburn
Green Status (L4)
Green Status (L4)
Postby vanderbeek [OP] » July 14th 2017, 10:39pm
Thank you very much for taking the time to post pictures, much appreciated. I'll try it your way and report back.
Have a great weekend!
vanderbeek
Return to Lifted Suspension
It is currently December 4th 2020, 2:52am
Lifted Suspension Forum
pmoupmou is online!
Comments: 75
Time: 3:41am
Date: Nov 29 '20
Time: 2:00am
pmoupmou is online!
Comments: 75
Date: Nov 28 '20
Time: 7:34pm
pmoupmou is online!
Comments: 75
Date: Nov 24 '20
Time: 11:40pm
pmoupmou is online!
Comments: 75
Date: Nov 24 '20
Time: 10:30pm
