Custom hangers, s10 springs leaf, problem with anchor plate
Postby doublebass [OP] » September 8th 2017, 6:52pm
Hello , what I can make now that I have replace the fiberglass springs leaf ?! The spring leaf turn a little bit because the anchor plate it's too large , any idea? Thanks
I am italian
doublebass
Years of Membership: doublebass has been a member for 3 full yearsdoublebass has been a member for 3 full yearsdoublebass has been a member for 3 full years
Topics: 38
Images: 50
Alias (AKA): doublebass
Extra Info: LT 4.3 v6 RWD
  • new S10 springs
    by sumtingbig » December 12th 2020, 4:24pm in Lifted Suspension
    Last post by MI_Ghost View the latest post
    January 25th 2021, 7:14am
  • S10/15 Leaf Spring Experts - Do These Options Matter?
    by Sparkydog » October 15th 2020, 12:41am in Lifted Suspension
    October 15th 2020, 1:50pm
    70
    January 28th 2021, 7:01am
Re: Custom hangers, s10 springs leaf, problem with anchor pl
Postby doublebass [OP] » September 8th 2017, 6:55pm
802178020980217
I am italian
doublebass
Topics: 38
Images: 50
Postby AstroWill » September 8th 2017, 10:21pm
I used plates and u-bolts and ditched the clamshells. See my Tiger v8 thread here: viewtopic.php?f=127&t=11729&start=200#p723162
Images: 464
Postby 97cargocrawler » September 9th 2017, 12:11am
I find it strange that the end of your overload leaf is touching the one on top of it. Am I wrong? Did you remove the overload leaf? Is there just a lot of weight in the van when this pic is taken?
Anyhow, you can loosely wrap bailing wire around the leafs to keep them inline, or you can do something a bit more extreme like this:
The U-bolt and top plate will not prevent your spring pack from scissoring but they are far superior to what you have there.
That gap between the clamshell plates suggests your bolts are not torqued to spec. If they were the plates would be bent around the bolt. At the very least you should consider putting some sort of spacer in there and torquing to spec.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby doublebass [OP] » September 9th 2017, 6:29am
Thank you ! No I don't remove nothing ! It's as you can see, maybe I need another one leaf?
Thanks guys !
Have you get off the shocks absorber for put on the springs leaf ? Is it better for install?
I am italian
doublebass
Topics: 38
Images: 50
Postby 97cargocrawler » September 9th 2017, 9:27am
If you add another leaf or the rubber spacer your problem with the gap will be worse.
I think your springs are probably very worn.
The leaf moving out of alignment is not a huge issue to worry about. Give it a few good whacks with a hammer and wrap some wire around. You will be fine.
97cargocrawler
Topics: 42
Postby doublebass [OP] » September 9th 2017, 12:32pm
I have replace the fiberglass springs leaf with this steel springs leaf, it's better than before ! Too expensive buy in USA a cause of taxes! Thank you
I am italian
doublebass
Topics: 38
Images: 50
Postby Coaster » September 9th 2017, 3:38pm
ok, those springs are beyond shot. they should not arch reversed like they do. they are missing the hardware that keeps them aligned. the front mount/hanger is not factory, at least it doesnt look like it. you have fiberglass setup on the axle which wont work with the steel springs the way you have it put together.
i'm doing the same thing right now, but i have a steel spring axle that is going in. what you have is not safe on any road
I LIVE IN NORTH DAKOTA
Coaster
Years of Membership: Coaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full years
Topics: 113
Extra Info: 4.3 cargo 2wd
Postby doublebass [OP] » September 9th 2017, 6:18pm
The problem is the anchor plate , mine is too large
The springs leaf that I have are free arch
Is it easy if I get out the shocks absorber when i mount the springs leaf ? Thanks
I am italian
doublebass
Topics: 38
Images: 50
Return to Lifted Suspension
It is currently January 28th 2021, 7:01am
Lifted Suspension Forum
Attached by: icebrrg3rd
icebrrg3rd
Date: Jan 22 '21
Time: 4:09am
Attached by: SportsBoy
SportsBoy
Date: Jan 21 '21
Time: 3:24am
pmou
Comments: 88
Date: Jan 20 '21
Time: 4:16pm
Attached by: mglsite
mglsite
Date: Jan 15 '21
Time: 2:02am
Comments: 328
Date: Jan 06 '21
Time: 12:09am
