Gen 1 Spring Perches and U-Bolt Plates
Postby AstronautFireman [OP] » September 10th 2017, 12:09am
Hey guys, doing a rear S10 spring swap on a gen1 '91 safari. I ordered the Crown Automotive # 52006421 plates as mentioned on astrowill's website. the plates are a bit too narrow to fit over the perches, even with significant grinding already done. To get the bolts to go through I'd either need to cut or drill out notches into the existing perches, and that doesn't feel right. Does anyone have experience with this, is there a different plate that has been used that might be a bit wider?
Thanks!
'91 Safari XT camperized and built for climbing mountains.
2" Lift, S-10 Springs, Rancho Shocks, Electric Fan, Solar System, Thule Box, Full Trad-Rack.
AstronautFireman
Years of Membership: AstronautFireman has been a member for 5 full yearsAstronautFireman has been a member for 5 full yearsAstronautFireman has been a member for 5 full yearsAstronautFireman has been a member for 5 full yearsAstronautFireman has been a member for 5 full years
Alias (AKA): AstronautFireman
Van Model Year: 1991
Extra Info: AWD XT
Re: Gen 1 Spring Perches and U-Bolt Plates
Postby AstroWill » September 10th 2017, 12:28am
Following the link, and scrolling down a little leads you to: viewtopic.php?f=127&t=11729&start=200#p723162
That post shows you where I drilled the plates to convert from composite to steel leaf springs.
As long as you don't grind away the sides of the existing perch, you will be fine. If you have already ground away the sides of the perch then you can order the Coreswest perches listed and weld them on.
Images: 472
Postby unblind » September 10th 2017, 6:16am
I opted to go with 3inch wide plates seen here
http://www.ebay.com/itm/172408824226?rm ... noapp=true
I think they sell 2.75 in wide also.
I decided to not drill the perch surface and instead do some grinding on axle. I am ok with a gap on the sides of spring. No pics of mine but look through Lumpys spring pack build, page 10, and see how his turned out.
unblind
Years of Membership: unblind has been a member for 5 full yearsunblind has been a member for 5 full yearsunblind has been a member for 5 full yearsunblind has been a member for 5 full yearsunblind has been a member for 5 full years
Images: 7
Van Model Year: 1988
Postby AstronautFireman [OP] » September 10th 2017, 3:17pm
didn't take off the sides yet, assuming this is gonna take a while to drill through!
AstronautFireman
Extra Info: AWD XT
Postby Coaster » September 10th 2017, 4:07pm
not really, its mild thin steel. drill a 1/8" pilot hole in 4 seconds, then step it up in a few more seconds.
I LIVE IN NORTH DAKOTA
Coaster
Years of Membership: Coaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full years
Topics: 114
Extra Info: 4.3 cargo 2wd
Postby AstroWill » September 10th 2017, 9:16pm
Coaster wrote:not really, its mild thin steel. drill a 1/8" pilot hole in 4 seconds, then step it up in a few more seconds.
Yep, doesn't take long at all, even quicker with a plasma ;)
Images: 472
Return to Lifted Suspension
It is currently March 1st 2021, 7:56pm
Lifted Suspension Forum
Attached by: SportsBoy
SportsBoy
Comments: 28
Date: Feb 15 '21
Time: 3:20am
SportsBoy
Comments: 28
Date: Feb 08 '21
Time: 2:46pm
pmou
Comments: 94
Date: Feb 05 '21
Time: 4:42pm
pmou
Comments: 94
Date: Feb 04 '21
Time: 6:47pm
Attached by: icebrrg3rd
icebrrg3rd
Comments: 28
Date: Jan 22 '21
Time: 4:09am
