Here is what I've found so far. I'm sure I could source some cheaper fasteners, but this will work for the first pass at it. Let me know what you think.
Front:
- ZON3296 - 2" Tall x 3" Wide Body Lift Blocks, $3.00/ea x Qty 6 = $18.00 + $12.15 shipping = $30.15 (http://zoneoffroad.com/product-acc?ki=402)
- M12-1.75 x 150mm CL 12.9 DIN 912 Plain Socket Head Cap Screw, $3.92/ea x Qty 4 = $15.68 + $5 shipping guess = $20.68 (http://www.fastenal.com/web/products/detail.ex?sku=39670)
- M14-2.0 x 150mm CL 12.9 DIN 912 Plain Socket Head Cap Screw, $7.44/ea x Qty 2 = $14.88 + $5 shipping guess = $19.88 (http://www.fastenal.com/web/products/detail.ex?sku=39700)
Rear:
- 1995-2004 Chevy / GMC S10, S15 Sonoma Pickup - Leaf Spring (Rear - 3/1 Leaves), $115.95/ea x Qty 2 = $231.90 + $39.39 shipping = $271.29 (http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=8939)... Assuming these leafs will give me the same lift as the Overlandvans.com 95-05 Astro/Safari +3" Spring Pack, 3+1 @ 1350# (http://www.overlandvans.com/0104_suspension.html)
Other:
- Bumper Relocation Bracket, I am planning to modify the existing bracket and not purchase the relocation brackets from Overlandvans.com. When I get a chance I will sketch up what I am planning to do in paint and post it. Worst case is I just move the bracket up, use one bolt and have a friend of mine weld it in place.
- Emergency Brake Cable Bracket, I will drill another hole in the existing bracket and re-use that.
- U-Bolts, will I need new U-Bolts? If so, what size will I need? I would probably just order these - http://www.sdtrucksprings.com/index.php ... ts_id=7488
In total doing the lift this way will cost about $350 with shipping included. I'll be installing everything myself so labor is "free". Any thoughts, comments or suggestions are welcome and always appreciated.
Thanks,
Dan
