I just got a new Dorman front sway bar to replace the hollow OEM bar and getting the rubber bushing and nut started on the bottom of the link is a bear. I searched on here and saw one mention of reversing the bolt and placing the head down below and the nut on top but when I did that I found the nut and threaded portion beyond it extend within 1/4” of the upper control arm. I’m tempted to saw off the excess threaded portion and leave it it that way.
Are there any secrets to getting that end link nut started inside that lower control arm like the original was? Thanks in advance for suggestions and by the way the solid Dorman weighed 18 pounds and the hollow OEM weighed 9; if that matters. I will follow up with my impressions of driving with the new sway bar.
