See descriptions in BURGUNDY for GEN1 85-95 variants.
Foreword:
Before starting, I must give thanks to our Original Members and Pioneers, without who’s hard work and trial-n-error, NONE of this would be possible... thank you for your contribution.
FAQ
What is a 2" Budget Lift?
We are talking about 2“ body lift pucks in front. For the rear, the standard shackle extenders will be used. This is by far the cheapest and easiest of all popular lifts. All in this baby runs right about $120 total! If your rubber body spacers are shot, plan on adding another $90 though.
Why the @#$#% would I do this?
As we all know, there are minimal suspension lift kits for these vans because they were never designed to be lifted. That being said, there are commonly 2 schools of thought to get that subframe up in the air… Body Spacers, Torsion Bar Preload, or a combination of both. Here is a side by side comparison:
Torsion Preload:
- A torsion lift (preloading springs) raises the front end by placing load on the torsion bars, using the adjustment bolts (that are actually designed for minor leveling adjustments), forcing the front end up. This reduces flexibly and travel since you are changing the starting point of those bars. This also results in decreased ride comfort for all the same reasons.
- Many lifts offer “Reindexed Torsion Keys”, which allow you to preload more therefore further reducing flexibility and making it ride like crap and cause accelerated wear on the front axles. You also would need to correct the angles in the front end by flipping the upper control arms ball joints and hope for the best.
Body Spacers:
- This is a plastic or machined 3” wide puck that you place between the rubber body mount and the subframe that lifts the body up and provides additional body clearance while not affecting the ride quality or suspension travel.
- This mod requires relocation of the emergency brake cable mount (new bracket or drill existing bracket) and trimming of the lower fan shroud since the subframe and drivetrain will now be sitting lower.
How Long will this take me?
Depends on your experience level, average is a good solid work day.
Of course it all depends on how much other broken/ funky crap or rusted bolts you encounter on the way.
Do I need any special tools or skills to do this?
NOPE! Just what you see here, comfy place to work and a little muscle / patience.
Is there a ton of mods required?
A few, nothing too complicated. In front, drill the e-brake bracket, trim the fan shroud. In the back... one little hole and ya done, not to fret.
What's the 2+1 and 3+1 lift?
The 2+1 lift is waay less evasive and does not require as many mods as the 3+1 and is recommend for beginner to intermediate shade-tree mechanics. The total bill as determined by the WimpTech R&D Team would be under $400 and done in a day.... VERY busy weekend.
Click here to view the 2+1 (3") Lift Thread (Intermediate) ---> viewtopic.php?f=40&t=121937
Click here to view the 3+1 (4") Lift Thread (Advanced)---> viewtopic.php?f=40&t=109802
SHOPPING LIST:
- (Qty 2 total/ 1 kit) Rear shackle extenders, see rear lift section for details. AirBagit / CTS
GEN1 (Fiberglass Leaf) PN:SHA-AS8400B Link: http://a.co/62phR2g
GEN2/3 (Steel Leaf) PN: SHA-AS8400A Link: http://a.co/0mGUrtO
- (Qty 6) 2" Tall x 3" Wide Body Lift Blocks: http://zoneoffroad.com/zone-offroad-pro ... -2in-/3296 ($24)
- (Qty 2) Extended Exhaust Hangers (http://a.co/1AKNozB) ($10)
- (Qty 4) M12-1.75 x 130mm class 10.9 hex head bolts: Link: http://www.tacomascrew.com/s.nl/it.A/id.7294/.f
- (Qty 2) M14-2.0 x 130mm class 10.9 hex head bolts Link: http://www.tacomascrew.com/s.nl/it.A/id.7310/.f
Also available from http://www.metricspecialties.com/ ($30 all in plus shipping)
GEN1 (85-95) VARIANT:
- (Qty 1) Longer steering coupler shaft from GEN2/3 RWD model (Junkyard or JOR) $10
Optional:
- (Qty 6) Rubber Body Mounts; Link: http://a.co/1hje2Mf (2 of the M14 mounts will have to be drilled larger, or just use your existing metal parts) $90
- This mod does NOT require new or modified shocks, stock will work just fine. However, whenever replacing shocks, you should make sure all 4 match each other in terms of compression and return rates. Therefore, you should either match models or replace all 4.
TOOLS:
Sockets: 8,10,11,12,13,15,16,17,18,19,21mm
Wrenches: 16,18,21mm
Vice grips
Floor Jack w/ blocks as required
Tall Jack Stands
Beer (as required)
SUPPLIES:
Thread lock
Brake cleaner
WD40
Ratchet strap (opt)
GEN1 VARIANT: JUNKYARD HARVESTING:
- When pulling the steering coupler shaft, get the rubber boot to go with it. This will save you the trouble of having to extend your existing boot. The shaft should be well greased and have almost no play when twisted. Bring a 8mm socket, 11mm wrench and pry bar.
FRONT INSTALL:
TIP: Proactively spray down all the bolts we are removing today with WD40 or similar. This will help the removal process and reduce down time screwing with rusty bolts
Prep:
Remove front bumper cover and subframe, as well as diagonal supports from cover ends.
Trim Lower Fan Shroud:
- Remove airbox w/ 8mm socket. Remove both upper and lower fan shrouds w/ 10mm socket. The bottom is tricky, be careful I snapped mine, then later just left it out all together).
- Trim the shroud until it resembles this:
Modify e-brake holder:
- Locate e-brake hanger bracket (near fuel filter, driver’s side).
- Use vice grips or similar to secure rear cable just past the adjuster. Use 12mm wrench to loosen (add slack) to the adjuster by turning clockwise.
- Pull apart cables at this junction. Squeeze/ remove retainer clip. Remove 2x 13mm bolts and hanger.
- Drill new hole farther up approx as shown below. Might make it better than this one… oops. Set aside for now.
Install Steering Coupler:
- Set steering wheel to straight forward; secure with bungee down to brake pedal to allow MINOR adjustment (key to ACC position). Thanks TurnNBurn for the tip!
- Remove 2x 13mm bolts and move fuse box to gain better access to top of boot and upper knuckle.
- Remove 4x 8mm screws on upper rubber boot, and pull lower boot off gear box (metal flex ring in boot).
(Boot removed)
- Remove 2x 11mm bolts, remove coupler
- Install new coupler with boots on (you can compress them together to get to the bolts), top end first, then align to teeth on gear box. Don’t let it move more than a tooth or 2 or your wheel will no longer be centered.
- Secure 2x 11mm bolts with Threadlock; secure boots.
Install Lift:
- Chock front and rear wheels or experience Darwinism first-hand.
- Remove front bumper cladding and metal sub-bumper (4x 15mm bolts)
- Remove body mount bolts x6. Front and rear are 18mm; middle are 21mm.
To lift your van off the sub frame, you can use a few different methods:
1- Lift the front end up by the cross member, then install jack stands under the sides to hold the body up. Then, use the floor jack to lower the subframe down.
2- Use a Hi-lift jack or similar as shown here by ericstg:
3- Position floor jack under front body approx as shown. If using a wood block like this, secure it to the jack to prevent tipping.
- Carefully lift body up off sub frame in small steps. Check for fitment issue or tight wires/ hoses. Stop when you can fit the 2” block on top of the body isolator.
Darwin check... once lifted, use those Jack stands, blocks or what ever and don't rely on just the jack or risk proving Darwin right.
Note: If rubber is badly cracked, smushed or otherwise hosed then consider replacement.
***-NOTE: 3" pucks pictured here***
- If pucks are not perpendicular, use ratchet straps or similar on the front of the van to pull it into alignment.
- Install new bolts through isolators and pucks. Use threadlock and torque to spec, or as hard as you can, don’t be Wimpy.
- Lower van, marvel in what you have accomplished… but not for too long, still got crap to do man!
- Reinstall e-brake bracket using new hole. Pry out tangs on the insert as required to secure. Reattach front cable to adjuster as shown in previous step. Adjust e-brake cable as required to ensure brakes aren’t dragging and work properly when pedal is depressed.
REAR INSTALL:
- Jack up rear end using common sense and as mentioned above to gain access. Hi-Lift jack with stands or if you have no budget, wood blocks n jack stands.
- Remove 2x 21mm rear shackle bolts, adjust jack to relive pressure on the bolts as required... don't drop van or axle on face.
- Using the appropriate shackle from the parts list, install extender into the top part first (loosely) as shown below. Then, swing it to meet the axle on the bottom most hole for 3" (or other as desired).
- Tighten all bolts and secure with threadlock.
To correct pinion angle and center rear wheel:
- Move to the forward rear leaf hanger and jack/ support as appropriate.
- Remove 2x 21mm leaf bolts. and move out of the way.
- You can either remove the forward hangers to drill or if you are careful, drill in place. DRILL IT STRAIGHT or the gods will punish you.
- Find center of lower portion (down 1.5 inches down(hole to hole)and centered in the bracket (about 1 inch up from the very bottom) and drill hole as shown here:
- Reinstall forward hanger/ spring into hanger and tighten with threadlock.
Front Torsion Bar Adjustment:
If needed to level out your ride, you can make adjustments to the ride height via the torsion bar adjusters. NOTE: If adjusting these, you should go for an immediate alignment or the gods will punish you.
- Locate Torsion bar adjustment bolts x2 in this area:
- Turn bolts clockwise to increase preload and raise front by ~1”. The amount of turns may vary, ~ 6-8 full turns.
- On a flat(ish) surface, measure between ground an wheel wells as required to ensure both sides are even and the desired height has been achieved.
Wrap Up
- Install bumper relocation brackets
WimpTech solution can be found here: viewtopic.php?f=11&t=100130
- Reinstall front bumper support or other bumper solution. Note: If reusing stock bumper cover, trimming will be required to ensure clearance with larger tires.
Go over everything:
- Bolts torqued down
- Wires and hoses have proper strain relief
- Tools removed
- No extra parts/ bolts, besides the 6 body mount bolts of course
- Plan on getting an alignment ASAP
Note: recheck torque on body spacer and leaf bolts after about 100 miles to ensure nothing came loose.
Crack open frosty beverage of choice… you did it.
For additional information and background on lifts, see AstroWill's site here:
https://sites.google.com/site/astrosafa ... safari-van
