I have read all posts on this forum acording torsion bars and I can not find any solution or explanation to my problem.
Im rebuild my Van for a last 6 months , almost everything is new, like whole new suspension from Moog, new pic steering pump, new brakes, new red head steering gear box and so on.
I also have a lift 2' , body spacers from overland.
My problem is that after we have change the whole front end I have notice that the driver side is much lower then the passenger side.
I find out that mechanic made mistake and pull off old lower arms without relaxing other end of the torsion bars ( "The Key side) So I ask him to do it again , but this time to relax the screw on the key side and pull the key off so the torsion bars are settle in a relax position. Then put the key and the screw back together .
So it did not help too much. I still need to crank leg side to 12 turns and right side to 8 turns only to get leveled front.
Is this difference normal?
Also Van is seating a lit bit too low as it is after 2' body lift on the high of 31,4 inch from the ground. In the beginning was 29,5 so there is a 2 inch difference ( so looks ok)BUT I put the new 235x70x16 tires opposite to 225x70x15 so the distance should be at least 0.5 inch higher
Other thing is that I have a problem with camber- to make it 0, it is on the minus side ( -0.1) , and the caster is also very low , somewhere between 2.24 ( I have read that should be around 3.5)
It shows that front suspension is still too low ( this is why is minus camber and low positive caster )
I still can crank the keys but why is the difference between 2 torsion bars torsion? ( why one side has 12 turns and 2nd only 8?)
