only one side rubbing
Postby aManAndaVan [OP] » April 25th 2020, 9:24pm
I just put on new tires (235/75/15) with stock suspension. i noticed the rear driver side tire rubs the front of the wheel well when im accelerating hard or going over a big dip in the road. so i added a 2 inch body lift and a rear lift kit from journeys( shackles and hangers). the rear is jacked all the way up. The rear isnt as lifted as i imagined it would be. ive only gained about 2 inches of lift and the tire still rubs.when parked theres 2 inches of space between the front of the tire and wheel well.
the previous owner had leaf spring helpers installed but they were on backwards/upside down so im pretty sure they were lowering not lifting the rear. i removed them but didnt get any additional lift( i did this before installing the new rubber and lift kit).
im now thinking the rear leafs are possibly worn leading to the rubbing. they are the stock springs from what i can tell(4 leafs). im more concerned about the axle play than the height at this point. ive checked the clamshells and everything seems tight. it should also be mentioned that the rear end was also swapped out with a rebuilt rear with 342 gears.... any ideas?
im planning on replacing the leafs with 1195s and U bolts if needed but hate just throwing parts at the problem.
is rear end alignment possibly an issue? can the rear be aligned on these vans?
any help is GREATLY appreciated.
before and after lift installed. the after pic is the pic with the front bumper cover on the saw horses.
aManAndaVan
Extra Info: SLT V6 4.3 RWD
Re: only one side rubbing
Postby Rockridge » April 25th 2020, 10:22pm
Possibly the body is out of alignment with the subframe? That would make tire rub different side to side.
Looks like it sits perfect
Rockridge
Firing on 8 Cylinders (L1)
Years of Membership: Rockridge has been a member for 4 full yearsRockridge has been a member for 4 full yearsRockridge has been a member for 4 full yearsRockridge has been a member for 4 full years
Topics: 46
Alias (AKA): Walker
Postby aManAndaVan [OP] » April 25th 2020, 10:38pm
The rear tire is rubbing.... if the front was rubbing i could understand the subframe alignment but the rear?
aManAndaVan
Postby AstroWill » April 25th 2020, 11:28pm
I'm going to go with worn out springs, probably wrapping pretty bad on acceleration.
Topics: 106
Images: 440
Postby Rockridge » April 26th 2020, 1:05am
Sorry, missed that it was the rear.
Rockridge
Topics: 46
Alias (AKA): Walker
Postby Mmusicman » April 26th 2020, 2:55am
It might not have anything to do with the springs (unless it's hitting the top of the fender).
Clam-shell bolts tight?
Rear may be shifting forward.
(looks off-centered in the photo)
Mine wasn't rubbing, but I found it was shifting.
I fixed it.. it doesn't shift forward anymore.
Firing on 6 Cylinders (L5)
Topics: 72
Images: 49
Postby Coaster » April 26th 2020, 4:23am
looks like drivers side rear wheel is too far forward in wheel well.
should be more centered in well
I LIVE IN NORTH DAKOTA
Coaster
Topics: 113
Extra Info: 4.3 cargo 2wd
Postby aManAndaVan [OP] » April 26th 2020, 4:30am
Clamshell Bolts are as tight as they can be. And yes its still not centered in the opening even after the lift. It was BAD with just the rear shackles. After installing the hangers i feel like im back to square one....So my other question.... can the rear be out of alignment? Can the rear be aligned on these vans?
aManAndaVan
Postby Coaster » April 26th 2020, 4:32am
have you taken the shells apart?
Coaster
Topics: 113
Postby icebrrg3rd » April 26th 2020, 4:37am
I go with the axle wrap...
Where the tire normally sits:
Under abrupt acceleration:
Driver side does it too but doesn't contact the fender.
I have a set of 4-leaf springs I will be mounting soon, which (I hope) solves this issue.
-Andrew
91 Chevy Astro 5L 5-speed, Ford 9" 261k mi
02 Chrysler Sebring Conv. 2.7L 5-speed 213k mi
10 Chrysler Town & Country 3.8L 180k mi
icebrrg3rd
Firing on 5 Cylinders (L3)
Topics: 49
Alias (AKA): Andrew
Van Model Year: 1991
Postby CopperFiremistCopperFiremist is online! » April 26th 2020, 5:00am
^That
Pullin The Pass
Firing on 1 Cylinder (L2)
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby augidog » April 26th 2020, 5:12am
CopperFiremist wrote:^That
ever since I got mine, I've been sure something's moving around in the right rear. It almost feels like a u-joint, or a tranny mount, until you pay closer attention. I don't have a 2nd set of eyes to help me figure it out, but I'm pretty convinced it's leaf-related.
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby Mmusicman » April 26th 2020, 1:25pm
aManAndaVan wrote:So my other question.... can the rear be out of alignment? Can the rear be aligned on these vans?
As far as I know, there is no actual rear alignment adjustment.
But can the rear be out of alignment? I'd say quite possibly.
A lift-shackle may cause some minor issue too (mostly when springs are unloaded), but the fixed pivot point (in front of spring pack) is stationary and fixed. It doesn't change. I would suspect any shift would be extremely minimal. It certainly wouldn't cause one side to be different than the other.
I actually accidentally discovered my rear was moving when I was taking drive-shaft yoke measurements.. and was wondering why I kept getting different measurements on different days. I also noticed the entire rear was moving in a video of me pulling a heavy load.
I attribute some of this movement to spring wrap, as well as soft or worn rubber bushing issues. But in my case the rear was actually moving.. and staying in place AFTER movement. I measured wheel to fender distance and found one side different than the other. My rear was actually crooked. Apparently, when I would brake, it would shift to one position, when I would accelerate it would shift to the other position. Finally, I hooked a tie-down strap around the rear and attached it to a frame point.. started cranking the strap and suddenly I saw the rear move! I thought "holy crap batman"! lol
In my case, when I took a closer look, I discovered the little bolt that goes thought the spring-pack had shifted forward as far as it could in the clamshell. I finally resolved my particular problem by not only torque-wrenching down the clamshell bolts, but by putting in a "centering spacer" (the same size as the clamshell opening) so it is centered and can no longer move. I also had to recenter the lift blocks on the differential mount. In my case, the clamshell bolts were no-where near as tight as they needed to be, but that's an issue related to using clamshells with lift blocks. Then while attempting to torque the bolts down even further, I had issues with the clamshell bending (with my block-lift application).. but that's another story for another post.
This was my "non-conventional solution" to prevent my rear from shifting...
I can't say this is your issue, but it was mine.
Something to possibly consider and take a look at ...
Topics: 72
Images: 49
Postby augidog » April 26th 2020, 2:09pm
Do I see no insulators? Is it really metal-on-metal by design? Could that be (part of) the issue? Collapsed or non-existent insulators? Spring vendors refer to insulators, but my service manual shows nothing. I will try and see if it's a factor on mine.
EDIT: i do have center insulators top and bottom on my OE 3-leaf suspension, but i also have corrosion and leaf separation/movement. Pics in my build thread. Thanks to the OP and contributors for the education.
augidog
Topics: 16
Alias (AKA): Augie
Postby AstroWill » April 26th 2020, 6:58pm
icebrrg3rd wrote:Image
Great pictures, could you do a video from under the van showing what the springs are doing when that happens, before you fix it :) Bet it makes a nice S shape when it happens, can kinda see how high the rear part of the leaf is in the second picture though.
Topics: 106
Images: 440
Postby aManAndaVan [OP] » April 26th 2020, 9:06pm
oh the possibilities!.... thank God for a community forum such as this. i think im going to take the axle wrap approach and replace the springs since disassembling the clams to inspect is already almost half the work. after driving around today i can definitely tell there is less life in the spring pack im having issues with. thanks for all your help!
as of now i was able to get away without the extended rear brake line but i have a feeling that after replacing the leaf pack im going to need it.
anybody here using front coil spring spacers AND a 2 inch body lift? am i going to NEED the steering shaft extension? ive heard mixed opinions in the past. some said that the 95-05 have a long enough shaft. thanks in advance
aManAndaVan
Postby icebrrg3rd » April 26th 2020, 9:11pm
Hey Will, I had my brother-in-law video that while I accelerated, wonder if I can get him to lie under the van while I do it...? :think:
Maybe I'll attach a dash cam under there before I do my leaf spring swap.
Oh, and when it does this, I can feel that the rear end is steering the van. And I do know that the clamps are tight and the axle-to-leaf connections are not moving.
-Andrew
icebrrg3rd
Topics: 49
Alias (AKA): Andrew
Postby AstroWill » April 26th 2020, 9:46pm
LOL, well for the health of your BIL would probably be best to mount it to the van. I was thinking of strapping a camera to the drivers side frame rail looking over towards the passenger side spring. Might have to remove the spare tire to get a better video showing the whole leaf spring. Lots of cameras have a screw mount on the bottom for a tripod, but can be mounted to a piece of flat stock with a proper sized screw(1/4-20).
Topics: 106
Images: 440
Postby SportsBoy » April 27th 2020, 1:43am
Yeah, IMO if the rear is "jacked all the way up" and there isn't much of a difference between the two pics, then you probably need new springs. If the PO had helpers on the leafs before, it was probably because they are shot.
SportsBoy
Topics: 18
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby aManAndaVan [OP] » April 28th 2020, 4:19am
installed new(used) springs today from a local pick.n.pull off an 05. found out my axle was shifted forward because the center bolt on the pack was sheared off. PO installed spring helpers because he intermittently carried 8 passengers and gear.... the helpers would bottom out on the end of the springs and then hit the clamshell causing it to shift and in turn shear the bolt.... got er fixed now and riding like it should. thanks again for the help
aManAndaVan
Return to Lifted Suspension
It is currently October 28th 2020, 6:44am
Lifted Suspension Forum
K-TRON
Date: Oct 23 '20
Time: 6:05am
Date: Oct 23 '20
Time: 5:16am
wilsc449
Date: Oct 21 '20
Time: 3:40am
pmou
Comments: 51
Date: Oct 20 '20
Time: 2:36am
Attached by: Sparkydog
Sparkydog
Date: Oct 15 '20
Time: 12:40am
