Stiffining the suspension for less body wobble
Postby 03GMCSAF [OP] » May 7th 2020, 5:29am
I recently lifted my safari and it is veey wobbly and when I hit bumps or aany difference in elevation on the ground the tries normally rub really bad for maybe a second. Does anyone know where I can buy stiffer springs?? or any ideas to help it out, just got new shocks too.
03GMCSAF
Alias (AKA): Sam
Extra Info: AWD V6 Lifted 4in
  • Upper body mount location ??
    by Digidonny » May 30th 2020, 3:13pm in Lifted Suspension
    Last post by offctr View the latest post
    August 11th 2020, 8:59pm
    October 29th 2020, 12:06am
Re: Stiffining the suspension for less body wobble
Postby augidog » May 7th 2020, 3:04pm
My 4-leaf "OE" replacement springs, 3 leaves plus a 4th helper leaf, are definitely stiffer than stock.
I chose Husky brand, through rockauto...1) because it looks like Husky Spring also makes the other higher priced brands and 2) RA had a very reasonable shipping charge compared to direct leaf spring suppliers.
With that said, "very wobbly" can also be a front sway bar issue, and you may need to add a rear stabilizer as well.
The best advise I can personally give is...the experienced members here are going to want more details w/pics in order to better help you through this.
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby SportsBoy » May 7th 2020, 3:20pm
Check out the lift threads or any of the many spring threads to get part numbers and suppliers for new springs - they have stiffer Astro/Safari springs and S-10 springs work too
SportsBoy
Topics: 18
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby Mmusicman » May 7th 2020, 3:51pm
03GMCSAF wrote:..the tries normally rub really bad for maybe a second..
Personally, sounds like a tire fitment issue to me.
Where are the tires rubbing?
Firing on 6 Cylinders (L5)
Topics: 72
Images: 49
Postby Manny ManVan » May 9th 2020, 10:30am
I want to increase my load capacity by using Sonoma/S10 leaf springs. How do I know that they are compatible with my 2002 AWD Safari with 3” lift? Short and long length measurements?
Manny ManVan
Years of Membership: Manny ManVan has been a member for 2 full yearsManny ManVan has been a member for 2 full years
Alias (AKA): Christopher
Van Model Year: 2002
Return to Lifted Suspension
It is currently October 29th 2020, 12:06am
Lifted Suspension Forum
K-TRON
Date: Oct 23 '20
Time: 6:05am
Date: Oct 23 '20
Time: 5:16am
wilsc449
Date: Oct 21 '20
Time: 3:40am
pmou
Comments: 51
Date: Oct 20 '20
Time: 2:36am
Attached by: Sparkydog
Sparkydog
Date: Oct 15 '20
Time: 12:40am
