Bouncy Rear End
Bouncy Rear End
Postby Manny ManVan [OP] » May 10th 2020, 4:07am
Since installing 2-3 inch JOR lift kit rear end is very bouncy and sway left to right on the highway while cornering. Replaced shocks at same as the lift. What is causing this? I figure replacing the leaf spring and adding some stops should help???
Manny ManVan
Years of Membership: Manny ManVan has been a member for 2 full yearsManny ManVan has been a member for 2 full years
Alias (AKA): Christopher
Van Model Year: 2002
Re: Bouncy Rear End
Postby Wiley » May 10th 2020, 2:55pm
What shocks did you go with, were they really cheap? How about the leaf springs, did you swap with stock or make a change? A 2-3 in lift should not change much, is the van empty or full when bothering you? I believe there is an option to add a rear sway bar, but again 2-3 is not much.
2guys1truck.com: 2004 AWD Chevy Astro from California to Colombia!
Wiley
Years of Membership: Wiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full years
Topics: 7
Extra Info: AWD 2 inch Lift
Re: Bouncy Rear End
Postby tungtide » May 10th 2020, 3:13pm
Better shocks for bounce. I used the Lumpy shock mod and stock size shocks. If you used shackle extension for lift, I believe that will ad to sway. Anti sway bar will help. The stops/bumpers should not be coming into play here unless heavy load. Best luck!
Ken
tungtide
Topics: 21
Images: 12
Alias (AKA): tungtide
Re: Bouncy Rear End
Postby Mmusicman » May 10th 2020, 3:28pm
Suspension is actually pretty simple:
* Shocks dampen bounce
* Sway bars control sway
* Lift (shackle, block, or body) has virtually no affect on ride.
(vehicle body is merely lifted higher up above stock suspension)
* Springs are springs.. (with different rates/load capacities)
Wrong springs can give weak.. or stiff ride.. but bounce is strictly controlled by shocks.
Manny ManVan wrote:Since installing 2-3 inch JOR lift kit rear end is very bouncy..
A bouncy rear end sounds like weak/bad shocks... not lift.
Test: bounce rear.. if it bounces more than once shocks are bad.
Firm good quality shocks won't bounce at all.. they will simply rebound to ride position.
As always.. I personally highly recommend KYB Monotubes. Great bang for the buck!
Nitrogen gas shocks have amazing control on dampening bounce in varying conditions.
...and sway left to right on the highway while cornering...
Higher lift can lead "some" increased sway and side-wind loading.
Not only more surface area for cross-winds, but higher center of gravity too.
Good sway bar is recommended.
Sway problems are often typically from poor tires or alignment too.
Passenger tires have WAY TOO MUCH flex in their sidewalls for vans.
LT tires (with firm side-walls and higher pressure) is STRONGLY recommended as well!
Firing on 5 Cylinders (L5)
Topics: 72
Images: 49
Re: Bouncy Rear End
Postby markmitch » May 10th 2020, 5:20pm
Or you could find some overweight people to ride in the back, just saying! LOL
hope you figure it out.
Firing on 4 Cylinders (L6)
Topics: 599
Images: 20
Extra Info: RS V8
Re: Bouncy Rear End
Postby Astro Pop » May 10th 2020, 7:28pm
Bounce is bad/wrong shocks, plain and simple. The JOR lift is longer shackles which needs longer shocks in the back. Using the original type shocks puts the shocks outside their normal range of movement. You'll need replacement shocks that are 2-3" longer. I went to 4 wheel drive to get new shocks and they looked them up for me. I forgot which part # I ended up with but they work great. I'm sure someone here has some numbers.....anyone...anyone? The Lumpy mod works great to clear the undercarriage if you're going to do serious 4 wheelin, but you need a good welder and welding skills.
Mmusicman is right. If you have passenger car tires on it....loose them. WAAYYY to mushy for our vans.
Edit: forgot to mention that if you go with the Lumpy mod you can stay with factory shocks.
Astro Pop
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Re: Bouncy Rear End
Postby Rinny » May 10th 2020, 10:12pm
My van corners like it is on rails. I went with the 2100lb rear leaf springs made or the van, Journey hangers and shackles (modified them a bit), modified the bottom shock mounts so they are even with the bottom of the axel tubes. The van rides a little stiff when all my fishing gear is not in it but when I am loaded to go it rides well. My front and rear bumpers are quite hefty which helps take out some stiffness in the ride. It does corner really, really, well
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full years
Topics: 56
Images: 6
Extra Info: 5.7L NP236
Re: Bouncy Rear End
Postby Mmusicman » May 10th 2020, 11:04pm
ALL springs suffer from the same issue.. they should be matched to the load they are carrying. Empty vans ride firm... loaded vans ride a little smoother. This applies to all vehicles.. particularly heavy duty trucks. There are very different definitions of "bounce".. but it's likely we're talking about slow bouncing up and down, and not a firm bounce over a small bump.
It also depends on the "feel" you are looking for. Some like a firm ride, some like it soft.
GM typically puts the ride somewhere in the middle.
Firm springs are also effective in preventing lean.
Personally, I prefer a firmer solid ride.
All springs bounce (at different rates)... and thus the job of the shock to dampen the rebound.
Shocks may need to be ideally mated to the spring rate.
The heavier the vehicle (or more sever the duty)... the heavier and firmer the shocks.
Weak springs, standard shocks.
Firm springs, firm shocks.
But ALL shocks must dampen rebound. If it bounces more than once, they are bad.
Gas shocks tend to be firm on rebound control, yet internal valving prevents them from being harsh on hard bumps. The pressurized nitrogen gas also prevents "aeration and fade" under severe duty, such as a long bumpy bouncy road.
The right shock is the key to a good successful ride!
So are the right tires.
PS: If your "stock length" shocks (on a lifted vehicle) are extending (reverse bottoming out) to their limit.. you will likely experience a whole new set of problems.
Topics: 72
Images: 49
Re: Bouncy Rear End
Postby Manny ManVan [OP] » May 11th 2020, 9:13am
I used the recommended Rancho RS55150 and RS55147. I think my leafs are just packed out?
I’m going to redo my lift once I’ve rebuilt my front end and use the S10 22687 springs. I want the extra lift and I want it to ride like a truck. I have a pop up rooftop tent as well as bike rack on the back. Thanks for all the input. Pretty much should have just read a few threads before posting.
Sounds like the new shocks I installed when I did the lift are not the right ones??
I’m running Goodyear Duratracs so it’s not a tire issue. I’m thinking it’s the shocks for sure.
Manny ManVan
Re: Bouncy Rear End
Postby AstroWill » May 11th 2020, 7:30pm
Definitely sounds like shocks.
In 2016 ~66mil voted for Clinton, ~63mil voted for Trump and ~100mil(eligible) didn't vote Make a difference - register+vote!
Topics: 106
Images: 437
Re: Bouncy Rear End
Postby Manny ManVan [OP] » May 12th 2020, 1:29am
Thanks for all the input guys! I’m will definitely paying much more attention to this site in the coming months. Major upgrades soon to come. Super excited.
Manny ManVan
Return to Lifted Suspension
It is currently September 28th 2020, 1:16pm
Lifted Suspension Forum
Jakob1994
Date: Sep 17 '20
Time: 5:03pm
Attached by: ri$e*above
ri$e*above
Comments: 9
Date: Jul 11 '20
Time: 7:10pm
ri$e*above
Date: Jul 10 '20
Time: 7:47pm
ri$e*above
Comments: 9
Date: Jul 10 '20
Time: 2:37am
Attached by: Coaster
Coaster
Date: Jun 28 '20
Time: 5:56pm
