Upper body mount location ??
Postby Digidonny [OP] » May 30th 2020, 3:13pm
Hey I have an issue ... replaced all 6 body mounts with 2in. spacers and the center body mount on passenger side the upper nut/collar is spinning therefore I can not tighted the new bolt. Can anyone tell me how to get access to that upper nut and if it is welded to the frame ? Thanks !!!
Digidonny
Extra Info: Leather
Re: Upper body mount location ??
Postby Digidonny [OP] » May 30th 2020, 3:51pm
BTW... it is the larger M14 bolt of the center mount
Digidonny
Extra Info: Leather
Postby Digidonny [OP] » June 1st 2020, 3:11pm
OK I thought I would respond to my own post ! There is no way of accessing the top frame nuts for the 6 body mounts. They are welded into the frame and fully inclosed in the frame.
1 locate area of the mount
remove carpet
you will see rows of weld marks that mark the body frame
drill holes
use a cutting tool to create a access point
use vice grips to secure the nut
Digidonny
Extra Info: Leather
Postby Astrofarian » June 2nd 2020, 1:53pm
That was the exact same scenario I had to deal with about 10-12 yrs ago when a buddy of mine called me at 10pm with a "spinning" bumper mount nut. He was trying to install a hitch to pull a tent trailer....and they were planning to leave @ 08:00 the next morning! Ah, good times, huh? Glad to see you got it sorted out!
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby Coaster » June 28th 2020, 5:56pm
wow your floor is in way better shape than mine
I LIVE IN NORTH DAKOTA
Coaster
Topics: 113
Extra Info: 4.3 cargo 2wd
Postby SportsBoy » June 28th 2020, 9:58pm
Holy cow
SportsBoy
Topics: 18
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby offctr » August 11th 2020, 8:59pm
Thanks this is just what I was trying to find out. I just acquired an 04 and each of the number 2 position body/subframe bolts are broken off flush with the bottom of the bushing sleeve. We went looking at these as a hail mary play when no matter what we did suspension wise the steering and ride had a mushy/wavy sensation to it. Did ball joints control arm bushings,tie rods, drag links,idlers ,shocks --all of it found some bad stuff fixed that and in the process rebuilt the whole front end. Still had this wavy gravy feel going down the road. Turns out 3 out of the 6 subframe bolts were missing (1) or broke off (2) and the body was moving on the frame (subframe was shifting under the body) as you went down the road and steered/braked/accelerated rounded a curve etc.
We caught this as I was following another guy down the road and he was like "there is something squirelly going on with your front end"(after all the repairs/upgrades.)
The one I replaced no problem but the other two are the central mounts on driver and passenger sides and have no way to get them out save cutting into the mount and pulling the remnants out and replacing the bolts and nuts, so I was just coming to see if there was access under the carpet or how you locate them.
have to wait a few days since I am still cleaning up all the deferred maintenance. And of course the coil gave out but we were going to tear into that this weekend do the full tuneup distributor checkout and loom all the wires (previous owner had tie-wrapped all the wires in a bundle ----wonder were all the multiple random misfires came from.
anyway that answers my question.
havent been here in a while the 99 soldiers on with close to 300,000 on the clock the 01 is now my daily work truck. My 03 got rear ended on the interstate by a texter and has gone to the great co-part yard in the sky. The 04 is my newest project now that the kids are in college and parenting pressures are lessened --my eldest still calls with "dad my honda wont start" "dad my honda wont go into gear" "dad my A/C dosent work""....So I'm back to wrenching on Astros with the goal of building MY weekend getaway camping vehicle.
:banana:
offctr
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: offctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full years
Return to Lifted Suspension
It is currently September 21st 2020, 7:29pm
Lifted Suspension Forum
Jakob1994
Date: Sep 17 '20
Time: 5:03pm
Attached by: ri$e*above
ri$e*above
Date: Jul 11 '20
Time: 7:10pm
ri$e*above
Date: Jul 10 '20
Time: 7:47pm
ri$e*above
Date: Jul 10 '20
Time: 2:37am
Attached by: Coaster
Coaster
Date: Jun 28 '20
Time: 5:56pm
